Ok, finally the stuff I orderd as arrived. I wish the companies would disclose if they have the item in stock before I order..jeez. Anyway here is a new addition.
Heres the install. This is with all NRG parts just so ya know.
This is what you'll need:
Since there are no airbags on the S13 you just pull the center staight off(use some elbow grease and make sure the wheel is straight before you take it off!!)
Pull straight back
The nut in the middle takes a 19mm( You may want someone to hold the wheel, I didnt so I used a breaker bar to give me leverage.)
Once the nut is off, pull straight back on the wheels with hands at the 9/3.(use elbow grease). Sorry no pic.
Next, take the short hub and place over the stem. Then place the nut back on.
Next, take the quick release and put it on top of the hub. Place the screws(6) it came with in to the holes.
Attach the quick quick relase hub to the steering wheel with the screws(6) given.(Its the piece with the ring)
Then enjoy!!
Here are the model #'s. All is universal except the hub.
More to come when the weather gets better.
