onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Sat Oct 27, 2007 9:46 am
Okay, so I finally got around to pulling stuff and taking pictures. Just to recap, my heater doesn't work at all, it's always cold air blowing. And only level '4' works; off, 1, 2, and 3 are all off when you move the level through them. And me rear window defrost doesn't work, but that's a whole different switch I think.
Here's my heater hoses that go to the firewall. They look hooked up right, but I don't really know what's right and wrong here. The bottom one goes tot he bottom on the engine. The top one looks a little kinked, and goes to the drivers side somewhere, and has that weird valve on it. Does this look correct?
Here's the wierd valve, it has a cable that goes somewhere under the dash. I can move it back and forth with my hand somewhat (the cable and the little valve) How do I check for proper operation here? Does it look right?
And finally, here's the back of the hvac when I pulled it out. Anything look wrong here?
Please help me out guys, I need a working heater badly. Let me know what needs replaced or fixed asap! Thanks!
