That's exactly what I'm doing! I have my 3MM LEDs ready to go!rjdmmfl1 wrote:I'll reserve any more comments until you have the final product done... you say you'll mount them "in" that piece, so my guess is you're going with the 3mm led's and drill holes and mount them inside that piece... that will look good! I will wait until you finish , looking forward to it!
GryStrm wrote:u saw my dims u requested right?...i was thinking of 3mm but i this it might get lost...i want them dominant..on or off....hence...the "bullet belt" look i went for.......i might just use 9mm shell casings as led holders!..yea thats gansta shiat rite dea....fo realz..werd lol...
i did a relay of leds ..4 sets of two using 100oms per series..u need the resistors to handle the power of the source...in this case..a 9v...so each led in a set takes 3.5...or 7v for the set...so u have to caontrol the other 2 volts...when i do my final model...itll need to handle at least 13.8 to 14...the power of the car while running...so ill bump my resistors...to 330's...GryStrm wrote:..well my engineering friend...its a tough answer....cause it aint linear..meanig the peice has a slight bevel to the face...which is why flat light wont do well...they'd end up point up..not out...there is a notch back where the part goes from the high beam sec to the low beam sect..theres a "curl" at the outermost part...but if ya wanna now the true dim of the length...(firgured by string trace) its 29.4 cm..including the curl..or 11.574803 in...which is rougly...11 11/32 give or take a 64th...the face bevel appears to be 70 degrees
ya well its sort of like, you could custom make an intake but it'll be illegal. or you could spend a lot more and get the same thing but with a CARB number and it wont be illegal. California is stupid about stuff like that. i mean even blake was talking about the reason why Stillen doesn't do stuff with our lights is because then it wont be DOT approved and they could get sued or something. so just wondering if it's illegal or not to do it yourselfdangeris wrote:
Then I guess the Audi RS8 is banned from being sold on Cali since its whole headlight assembly is done with LEDs
Thanks for the advise I think thats the best idea, question for you though, while I can pick your brain, when you are done how are you going to draw power to the LEDs?? And what is the voltage and amperage coming from said source?GryStrm wrote:like i said in another post.....now that our 08's have been out for a while...and some have met with an early collision dimise...collision yards...even if the light is slightly scratched....get it...if u get ur design and technique down using that....then get a clean set and mod that as your final...dont rush is the key get it right make it work....and make sure itll last...they will draw a s load of attention....and you dont want it slopy...
Looks great Gry. Are you running the LEDS in series or parallel?GryStrm wrote:heres an idea of the light on the car....just an idea....i think its sexy....
