QX4 Headlight Lens Removal
Kellsonm
Car: 2001 Infiniti QX4
Hello, anybody know how to remove the headlight lens on the QX4? I'd like to remove the amber reflectors.
Thanks
atraudes
Car: 2001.5 Infiniti QX4 4WD
You're talking about cracking the housing open, correct? :dblthumb:
Kellsonm
Yes I think so
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
atraudes wrote:You're talking about cracking the housing open, correct?
I took the amber inserts out of my corner lamps on my pathfinder a few years ago after reading this thread.
Should be the same process for your headlights.
It sounds easy, but you really need to be careful and take your time.
I used a heat gun to soften up the sealant, but I went at it very slowly so as not to melt the plastic housing.
You also need to re-heat the sealant when putting it back together so that it seals properly.
I also put an extra (small) bead of silicone around the edge to make sure there are no leaks.
The last thing you want is to have water vapour in the lamps.
Good luck.
Kellsonm
Oh boy sounds pretty intimidating. Thanks for the help
Buzzman
Intimidating? A bit.
Time consuming? A lot.
