silvia tech »
https://forums.nicoclub.com/silvia-tech-u72042.html
Sat Sep 15, 2007 2:54 am
I recommend replacing the head gasket as Ilikemy240sx said. ARP studs and a reputable headgasket manufacturer, Apex, Tomei, HKS. I had a customer that blew a headgasket, I determined this by the white smoke bellowing out of the exhaust and the coolant smell from the exhaust. I told him to leave it and replace the head gasket and studs. He decided to drive it home. about 10 minutes after he left I recieved a phone call asking me to get the truck and trailer. We got the car back to the shop did a compression test and it was all over like 170, 30, 75, 200. I pulled the head off and noticed the cylinder walls. the coolant and oil mixed giving poor lubrication and the walls done for. To anwer you question it will more than likely cause damage minimum new studs gasket and sending you head and block out to machine shop to get decked. If you were my customer it was more cost effective to drop in a ned long block than to pay for that kind of machine work and bottom end parts. It is nothing that you cant replace as you said but it is your money a gasket and headstuds are cheap now. How cheap will it be if the headgasket blows out and you are looking at motor and a headgasket and studs or even machine shop work. Fix it right the first time, do the headgasket and studs now.
