Zilvia33 »
https://forums.nicoclub.com/zilvia33-u54046.html
Wed Jan 02, 2008 9:43 pm
Okay so i got a SR swapped into my hatch in late Oct, 2weeks before i moved up to ohio.
well since the 1st day ive picked the car up i've had trouble getting my car started. when i turn the key i can hear the fuel pump come on but as i turn the key, i just hear the motor turning, but it wont turn over, and when it does you can tell there is no igniting of fuel pushing it down. Now i know its Winter so the cold plays into affect, so over pretty much the whole month of Nov, and early Dec, i was starting my car by spraying some ether into the throttle body........so now my plugs are a we bit fuked. i was trying to get my car started before i left ohio for xmas break but no luck, even with the ether she just wouldn't start. Now a couple days before that we had my car barely running ( it was about 24 degrees out) and we were trying to get it out of the drive way so we could plow it. It was idling at about 200rpms, and under 3k (trying to warm i up) it sounding like it was running off 2 cylinders.
so does any one have an idea on whats going on, or how to fix this problem. i was told that, i believe the ignition wire, might be messed up or something......any tips?
also, the last i could remeber when it was running right-ish, my car would idle at like 1500rpms after its start and warms up, is that normal?
