Zyphar wrote:If i put the stuff into the crankcase (oil), do i just keep the car running on idle (for the oil pump to circulate the oil?) or do i keep put the car off for 20 mins.- the directions arnt too clear about that. ( putting seafoam will thin your oil buit is it ok if its idling?)
Also, when i pour through the booster line, the directions say that i the mixture must be %50 fuel & %50 seamfoam. Is this neccessary or can i just pour pure seafoam.
When it says to turn off the ignition, do i turn off by completly flooding the motor with seafoam or just when the smoke appears ?
and last question, when i pour it in the gas tank, i pour just 1/3 into the tank and then fill it with 10 gallons or is it another ratio ?
I'm by no means an expert, but I'll answer what I can.
With the oil, I read elsewhere that running your engine hard with Seafoam in the oil would dangerously thin your oil, so I just added the Seafoam, then let it idle for 20 min. No ill effects came from this in my case. Couldn't really notice a difference after this step, either, so I can't say if it made that big a difference or not.
I don't think that 50/50 thing applies to our KA's. I don't have a bottle in front of me, but I think that had to do with carburated engines.
The first time I ran a 1/3 bottle of Seafoam into the brake booster hose, I dunked the hose into the cup, which sucked the Seafoam up in about half a second, and quickly killed the engine. I was able to start the motor just fine, and lots of smoke insued, but I'm guessing the Seafoam didn't have a chance to get very deep into my engine. The second and third times, I fed the Seafoam in slowly, slowly enough to keep the motor running while I fed it in. Those times, it produced a ton more smoke than the first. Since smoke is a good thing in the case of Seafoam, I'm guessing the Seafoam had a better chance to do its job the second and third times.
Again, I don't have a bottle in front of me, but I think it specified the ratio of gas/Seafoam. Another thread on Seafoam said to add 10 gal after pouring in Seafoam, which is what I did. Worked for me.
