+1 on Enthalpy, it's well worth the $500 knowing it'll get done the RIGHT way. (However he seems to be slow on customer service lately- but in the end still a good tuner.)480sx wrote:
Id recommend Enthalpy personally, his tunes are great.
Yeah I ran across him a couple of times but can't quite afford him yet.What FMU do I go with?I read a little chart thing when I was searching but I just don't understand whats going on. I found a guy with a similar set up that I'm going with and he's Running a 6:1 on 9-10psiI r confused.480sx wrote:Tuning and hacks dont go well together man. If your going to spend money anywhere spend it on your tune. Or just run a FMU, stock injectors and low boost until you want to spend the cash.
I'm just going to do a T3/T4 set up till I want more.GTR PrYdE wrote:Well whats your setup?
lol I'm not gonna run 10 psi, more like 8480sx wrote:Its all about your AFR's. I have heard 8:1 does the job, 6:1 probably works too you just need to either have a dyno check out your AFR's or invest in a wideband.
9-10 psi is high for a FMU imo. It can be done safely with at least a 3 degree base timing retard but that effects drivability.
Personally? Only if it didn't work.s14tan wrote:Would you guys be mad if I started "Project eBay KA-T"?
Lol meh, never hurts to have another Ebay first hand experiance around.s14tan wrote:Would you guys be mad if I started "Project eBay KA-T"?
You know it! I've been talking about it long enough, But I just got a ticket today so now I have to pay that ish off first.simmode1 wrote:Awwwwww Snap! Tan about to go turbo!
What is the difference between the T04E and a t3/t4 turbo? I always thought that they were the same.480sx wrote:
Your going to go with a t4? Seriously just go with the t3.t4 50 trim you will be much happier with the results. China makes plenty of them. ]
Make sure you use an oil restrictor or you will have problems with the cheap turbos.
talk is cheap, just do it LOL .... boost is addictives14tan wrote:You know it! I've been talking about it long enough, But I just got a ticket today so now I have to pay that ish off first.
T04[E], etc is referring to the compressor side of the T3/T4 turbo, which is a hybrid, using a T3 on the turbine and a T4 size on the compressor. T4 = T04. the "E" or sometimes you see "S" are the different wheel/trim size compressor size, the "S" is bigger than the "E"....s14tan wrote:What is the difference between the T04E and a t3/t4 turbo? I always thought that they were the same.
