Oh and the car came with a ACT stage 2 clutch, if it helps.
Thanks in advance
And boom goes the dynamiteRazi wrote:Check your clutch lines and fluid.
Sounds like you have a leak or air bubble somewhere and you're not able to disengage the clutch all the way.
No actually it never felt soft, i had to push it in instead of just putting my foot on it lightly. And we will check the fluids, hopefully that will solve the problem. But i took it for a drive today it shifted fine. SO i hope its the fluids...Crautz240 wrote:Did the clutch pedal feel soft at any point in time, do like razi said and check your fluid first. If that isnt it, its possible that your synchros are going bad
Ok also i've got a another problem, now the speedo isn't working. I looked under the car and there is a wire hanging down there. it looks like it can be the speed sensor connector, its right towards the middle of the car. So would a lower harness, a brand new one, fix that??kouki munster wrote:Next time it does it stop and pump the clutch pedal and see if it gets better or goes away, if it does then you are some how getting air in the line which means that the master or slave cylinder is most likely going bad.
