Hello,
So, I had a previous thread here about my torque converter not locking up, and now it seems like it's something to do with the Throttle Position Sensor, so here is what is going on.
1 - Starting is very difficult if the car has been run recently. The trick I've found is to turn off the fuel pump, floor the throttle and once the engine runs, let off the throttle slowly (keeping the rpm below 2000), and turning the fuel pump back on and balancing the throttle to keep it running. Then it'll idle, but around 1000 rpm, and tons of fuel coming out of the exhaust!
2 - When my mechanic replaced the timing chains, he said it seems like the injectors are sticking open when the car sits for a while, which makes sense for it running rich till it warms up, and hard to start.
3 - While driving, the car runs GREAT, motor is smooth and powerful. . . but idle is high, and sometimes the torque converter never locks up!
4 - So, it seems like the transmission is ok, but something wrong with the motor, probably the throttle position sensor. If it was just the injectors, I'd assume there would be no problem with the Torque Converter locking up.
So, what's the best way to see if the TPS is working correctly?
Anyone else have any ideas of what is going on?
Notes:
- Millage is about 185K miles
- Fuel pump replaced about 170K miles
- Same time, I repaired the FPCM, and have a
backup switch wired in to bypass if it goes bad!
- Timing Chains replaced about 180K miles
- Through out the years, off and on, I've had problems starting it, it'd get flooded, normally in extreme hot or cold temps. Some times it'd be good all year, other times not. Trick's I'd use to start it, was first flooring the throttle and cranking, if that doesn't work, pull the Fuel Pump fuse and same. Now I have a switch wired to shut off the fuel pump.
Previous Thread:
torque-converter-not-locking-much-t522943.html
Thanks for all your help,
Vin
