Fezzik wrote:Is there a reason the tein H-tech lowering springs will not work on the M35x 08 model?
I am not an expert, but on this forum, many people have installed the H Tech springs from a non AWD onto the AWD with out any issues. I would suggest that initial design was based on the M and that since the overall suspension set between the AWD and Non AWD model is basically the same is the same, the H Techs should work.
There is a member on this forum who as actually installed a H and S Techs from a non AWD on a AWD with out issues.
Good luck, by the way I am in the same boat.
