Ziggy1621 »
https://forums.nicoclub.com/ziggy1621-u205397.html
Tue Apr 08, 2014 3:00 pm
Pull the side and bottom (the one that covers access to the TBL). Under the side covers, you will find a place to unplug the TBL on the driver's side, and the heater on both sides (a plug and a bolted ground). Then unplug your washer sprayer hose. Have your buddy hold the hatch up and unscrew the struts. Then I used a ratcheting wrench (12mm) to pull the 4 bolts off of the Hatch side of the hinge.
And yes, it is very heavy
