If it's road striping paint (I assumed it was) a clay bar will not remove it. Wetsanding will, but it will also remove too much clearcoat around the paint specs. You would need to use something like "Ronsonol" lighter fluid, or "WD40". The WD40 might work, might not. The lighter fluid will work. You will need to at least buff out the clear after using the lighter fluid. If you scrub the area with the lighter fluid, you will ruin the clearcoat. The reason that I suggestedcwetsanding, is after you use the lighter fluid, wetsanding will thin the clearcoat, and give it a nice slick look.abdoman wrote:I would not wet sand your car until you try a clay bar. A clay bar will remove paint overspray, especially latex paints. I've used a clay bar to remove paint. It's takes a lot of elbow grease, but you can really screw up your paint job if you don't wet sand properly.
Did you try calling Mayor Bloomberg?G35X07 wrote:I parked my car on Queens Blvd for couple hours at a meter parking...and when i got back to my car...there was tiny spots of white paint all over my car....can any one tell me what i could do?i tried wasshing but it didn't work....
Where is ur shop....WhiteyClay wrote:I see ure from brooklyn...I got a good shop in brooklyn that could have done it for u...I guess its 2 late...
lol omg, dealership. lol omg, $350.G35X07 wrote:Thank you Guys for the advice.. i decided to take it back to the dealer...they said they have a cleaning process which might work...they said it won't damage the paint....$350.00Lets keep our finger cross!!!!!!!!!!!!
