gwoods wrote:Now given the road test of the Viper with a 11.7 1/4 at 146 don't you think its possible the at the GT-r could have done 11.7 at 149????
The ZR-1 looks like a better match up to the GT-r. It ran the same to 60 but did the 1/4 mile in 11.0 couldn't find a speed.
Look at what car it was. It's a Hennessey Viper. That thing has some 2 times the HP the GT-R has and only 2 drivewheels. I recall reading either that comparison or one similar to it. It had serious traction problems. The 0-60 times tell all. Notice the Veyron. It has a lot of power (1001 HP) but a lot more weight(4400 lbs) than most of the other cars in the test. Yet it's 0-60 is incredible. It's the only one in the test that has AWD.
Here is an exerpt from the article the numbers you posted was derived from:
"Steve describes it best: "Holy Hell! This is a wild ride. It just wants to go sideways in every gear. When you're taking off, you've got to be so careful with the throttle. In 2nd, you've still got to be careful. It'll take a bit more throttle in 3rd. When you put it in 4th, you can go flat, but I had it snap loose with wheelspin. It's not until the middle of 4th gear that the Viper is really hooking up, producing lots of horsepower and torque.""
http://www.roadandtrack.com/ar...=5675
I'm not sure of the gear ratios on the Viper, but I'd speculate it may be completing the quarter mile within 4th gear. And according to this article the Viper had traction issues up until the middle of fourth. You might think the speed-dependent boost system might have some effect on this, but with traction being a problem even at high speeds, I can't imagine any effect the speed dependent boost would have would make that much of a difference. At least not to the tune of almost 30 extra mph. By Comparison, the Lingenfelter Corvette in that test was rated at 880 hp and 300 lbs lighter than the Viper. Although it didn't get a chance to run on drag radials, the 0-60 was higher than the Viper despite the Viper only having about 800 HP between 0 and 60 mph.
Another tidbit of info I'll throw in is that a stock Viper SRT-10 runs a 3.7 second 0-60 and completes the quarter mile in 11.9 seconds at 124.4 mph. That's .6 seconds faster to 60 and only .2 seconds slower to the quarter mile than the Hennessey version. But the huge difference can be seen in the trap speeds. Meaning the Hennesey Viper is getting out of the hole slower, but accelerates at a much faster pace once it can get some level of traction going.
Note the power to weight ratios of the cars from that article. Then, compare them to their respective quarter mile trap speeds. There is much more relavance than their quarter mile times. There are of cousre some anomolies, in teh Veyron and the SLR, but they are not to the tune of a 30 mph difference in their trap speeds. In actuality, the GT-R is a bit of an anomaly as it's power to weight ratio is just over 8 lbs per HP, yet it pulls off a trap speed similar to that of the Murciélago.
Hennesey Viper - 3.1 lbs per HP; 146.7 mph; 11.7Lingenfelter Corvette - 3.7; 136.4; 12.3Bugatti Veyron - 4.5; 137.9; 10.6Ruf Rt 12 - 5.1; 127.2; 11.6Mercedes Benz SLR McLaren - 6.3; 128.1; 11.6Lamborghini Murciélago - 6.9; 119.4; 12.3
