gt2871 upgragde bottom mount
jongonzoS13az
Car: 90 240sx
ok so i was on 240sx motoring.com and it said if you want to use the original turbo setup and upgrade the gt2871 you would have to customize a turbo intake pipe. something like that. has anyone done this upgrade and is there any pre manufactured pipes to do this..
adrianfromthecastle
Car: 1992 Nissan 240sx
I think the pipings the same, its the coupling that attaches to the turbo that needs to be bigger, i think
srdub-t
Car: white 91 SR22 powered coupe 240sx, 95 black c36 amg
i dont think they make a premanufactured pipe but its not much work at all, youll need lines also
nwmrkt
Car: S13
so if I get the apexi super suction intake made for the stock turbo...it will fit the gt28? With a new coupler?
Thanks
usdm_180sx
Car: 1993 Nissan 240SX base S13
Garrett makes a gt2871r with an s15/s15 t-28 style inlet and phase2 sells adapter plates to make it a true bolt on application. With that much air going through you'll want to get the apex/greddy/hks super suction kit which has a metal intake pipe.
nwmrkt
Car: S13
S14SRPilot wrote:Garrett makes a gt2871r with an s15/s15 t-28 style inlet and phase2 sells adapter plates to make it a true bolt on application. With that much air going through you'll want to get the apex/greddy/hks super suction kit which has a metal intake pipe.
thanks man, just looked it up.
ILikeMy240sx
Car: SR Power
I got one of them GT2871r with T28 style compressor housing. I was able to use my stock intake pipe by cutting the stock pipe and welding it into correct angle then picking up a turbo outlet made by Greddy that way I can use S13 hot pipe.
jongonzoS13az
Car: 90 240sx
thanks for the replies. can someone post a picture of this so i have an idea of what it looks like
ILikeMy240sx
Car: SR Power
sure thing buddy.
Check this out.zerothread/178547
jongonzoS13az
Car: 90 240sx
perfect! gnarly setup btw
