SR turbo upgrade... [PICS]
ILikeMy240sx
Car: SR Power
Long story short. T25 blew out. Now one thing led to another and I have the whole 9 yards now heh. GT2871R + 740cc + Z32 MAF + Enthalpy
I love it when boxes from parts start piling up in my room...
Yes, I am officially broke now.
Z32 MAF + Apexi filter + Tomei pigtail
All turbo gaskets
DeatschWerks 740cc w/ flow ratings. Awesome.
GT2871R T28 style. Compressor inlet pipe cut and re-welded for redtop. Greddy compressor outlet pipe to work with S13 hot-pipe. Megan O2 housing.
From the outside it just looks like a T28... sleeper (that's what I plan to tell people)
Dual Ball Bearing CHRA
Enthalpy tune. The chips even have my initials on them haha.
I can't even go to sleep anymore... I need to slap this thing on ASAP...
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
nice! yea def need to get that stuff on there.
nvrplzd240
Car: 04 G35, 02 CBR600 f4i, 90 Sentra
sweet man! its gonna drive like sex with all that on it
whiterps13
Car: white LE hatch
Awesome stuff, I cant wait to see some numbers.
roplusbee
Car: 2007 350Z NISMO
Wow. I hope I can make mods similar to that in the future (like this time next year). Keep us updated on your progress. Also, what made you go with that turbo over the GT28RS?
le_ryan
Car: Mazda3
91 Nissan 240SX SR
luckyy
ILikeMy240sx
Car: SR Power
GT2871R (.62 a/r ex housing) over GT28RS
because they have similar lag but GT2871R has better top end feel and more power
BTW, that turbo is identical to HKS GT-RS minus the GT-RS tag and the price
AmoebAssassin
Car: 1991 Base fastback 5spd, black
I saw that pic on facebook :D
~4N~
That's hot.
ILikeMy240sx
Car: SR Power
So the first thing I did was to make Z32 MAF fit using the stock intake hose.
Notice the size difference between Z32 and S13 MAF
The filters are identical... Z32 on the left SR on the right (only used for 2k miles...)
The mounting points are different.. Why you NEED to get a Z32 Filter
Ok so on to the air hose... Notice how the SR intake hose will not just fit on to the Z32 MAF
Solution: 3" -> 2 1/2" Coupler + Steel section
I got the steel section at a local AutoZone in their exhaust section. They sell bunch of little steel sections like this. For your reference... Size is about 2 5/8"
All assembled
I will probably cut that steel section shorter.
NiSmo240luvR
looks awesome man. definitely post up some numbers after you get it all on. now the question is how much you gonna sell me the apex-i filter for the SR for?
ILikeMy240sx
Car: SR Power
Haha sorry... all my spare parts like ECU, injectors, fuel rail, MAF, filter will be sold to one of my friends. He has helped me tremendously with many things so payback time
roplusbee
I feel you. I looked at the price tag though. I was thinking of doing the FPBig28 upgrade on the T25 from the stock SR20 Redtop. But now that you mention it, it does seem like the logical choice. Sorry I asked a stupid question.
BTW, thanks for posting those pix showing the Z32 vs SR MAFs. Now I know what to look for. You da man. Looking good. Keep us up to date bro.
ILikeMy240sx
Car: SR Power
http://shop.hybridynamics.com/...D=200
Where I got the turbo. Hybridynamics is awesome. Fast shipping and friendly service. My turbo came assembled wrong but they took care of that by sending new brackets and a HKS actuator at no extra charge for the inconvenience. I originally got their Garrett actuator that didn't fit and compressor housing was clocked wrong.
FPBig28 is ok I guess but for my power goal, it would be straining the turbo a bit. Besides, for few more bucks you get GT2871R so why not?
roplusbee
That's what I'm sayin. I need to myself for even typing that stuff earlier. You are telling my nothing but the truth. And I have learned the hard way before about trying to cut corners. Just do it right, the way you want, the first time and be done with it.
Good stuff dude.
BTW, what suspension mods do you have?
ILikeMy240sx
Car: SR Power
I just have Nismo S-tunes for now.
ILikeMy240sx
Car: SR Power
Soo... I took my turbo+manifold+lines+o2 housing off yesterday.. Decided to mess around with the turbo while I'm stuck inside today. So here it is...
Ok now you can't just bolt on the T25 oil return flange. You have to widen the hole.
Like so...
Just match it up with the gasket of your new turbo to see how much more you have to grind...
Bolted on the turbo... good time to buy a new hose (5/8 heater hose fit perfect) I bought a foot to have plenty of length to play around with.
Taking the stud off the T25 compressor housing to transfer over to the T28 housing. Instead of using a vice grip... you can use two nuts. Tighten them to each other and use the bottom nut to twist out the stud.
Comparison of the two... I think it's quite obvious which one is the GT-RS
Notice how the two turbos are clocked differently... I am going to reclock the center housing of the GT-RS turbo to closely match the T25 turbo for easier installation. All you have to do is loosen all the bolts holding the center section and turn the center section while holding the compressor and turbine housing still. You do not have to take the bolts out... Just loosen them enough for you to clock the center section.
After reclocking the center section... GT-RS matches the position of the T25 center section.
Also, T-25 does not have a built in oil-regulator. You can see the shaft if you look straight into the oil feed.
Notice GT-RS you cannot just see the shaft down the oil feed. The orfice is blocked by some sort of brass material.
If you look closer, you will find a tiny hole on the side wall of that brass material. That is the built in oil-regulator.
Now, it is my understanding that Garrett only started doing this recently so just check your turbo to see if you have one. If not, you need a regulator if using SS lines.
Now, let's explore how well the stock T25 turbo lines fit on to this turbo.. Also we will see how much bending is required. I am going to use SS lines but I wanted to see how close they are to lining up.
The water feed line... It hits the larger compressor housing...
After a very little bending... Now that doesn't look too bad. I am not sure how close it is to the hole on the block but should line up pretty close from the way it looks.
Water outlet line... No bending done and it lines up pretty nicely.
Oil feed line... No bending and it seems to line up pretty well.
All the lines looked pretty good. I am sure they will require a bit more bending but nothing too major here...
One more shot of the oil drain. Lines up good. Only thing you have to do is widen the holes.
By the way... did I tell you how much I hate using these stupid "ratcheting" wrenches? AAAAAAAAAARRRRG they are so much frustration...
I thought Id take a panaromic shot of the room... pretty damn messy...
Stay tuned...More will come
nvrplzd240
sweeet
what kinda numbers are you expecting to make?
ILikeMy240sx
Car: SR Power
350 whp is my goal.. I will be happy with that. I think thats about the limit of the turbo. (.64 turb housing)
Then I starting ripping apart my suspension.. hehehe
eds13
niceness! whats the toilet paper for?
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
to clean up the mess in his pants when he is finally finished and its installed. it will go along for the maiden voyage so he doesnt destroy his interior. good luck dude everything looks awesome! i envy your ability to do what i want to lol peace
ILikeMy240sx
Car: SR Power
hahah Im too cheap to buy real kleenex so I use TP for everything. Its so cheap and I can't justify buying kleenex...
I use it to clean up if i spill things and blow my nose... etc etc etc
ILikeMy240sx
Car: SR Power
MeanGreenS13 wrote:to clean up the mess in his pants when he is finally finished and its installed. it will go along for the maiden voyage so he doesnt destroy his interior. good luck dude everything looks awesome! i envy your ability to do what i want to lol peace
hahahaaha
I havent driven a SR 240 with upgraded turbo yet so this should be very exciting..
nvrplzd240
whens it gonna be ready to drive?
ILikeMy240sx
Car: SR Power
end of this weekend.. Im waiting on my SS lines.. Thats all I need.
JesusLikesKFC
Car: 91 240sx, geo prizm
doood it all looks so nice it makes me wanna slap yo mamma. how much $$ did it set u back?
roplusbee
Wow, 350 WHP is gonna be the shizzle. Nothing like a good suspension though. Going fast in s straight line can be fun, but going fast while cornering is better. Looks like you are gonna have fun with your new toys. Keep us posted dude. Laterz.......
karmakaze
Car: 98 240sx SE
nice dude. that setup is similar to mine. except I have the .86 and the 3" inlet housing on my gt2871r. (it made getting intercooler and intake pipeing waaay more difficult than your is, lucky!)
anyways, you will love it dude.
get the stainless braided lines though. you will regret it if you don't.
ILikeMy240sx
Car: SR Power
Yup.. one of the reason why I got this turbo was for ease of installation and awesome price at Hybridynamics. It was 998 bucks or something.
Oh and yeah I have a set of SS lines coming my way but I did this just to see and to show people what to expect if they are using stock T25 lines.
I've heard some people saying "It's impossible... too much bending" etc etc and I wanted to verify that for my self. My conclusion is that if you clock the turbo the right way then you can minimize the bending alot.
hydro123
Car: nissan 240sx
hey what rear bumper is that in your sig?
