I kinda wish I had jumped into this thread earlier.
I will try to sort some of the points that re-occur in this thread.
Now, my experience is with the PLMS cable, as the builders/programmers of the cables and Nissan DataScan live here, in Adelaide.. (Same city as myself)I believe most of this info will apply to the Nico OBD cable.
**NOTE: The interface worked flawlessly on my car. And I am running an IMPUL ECU, so a stock ECU is not necessary for the cable to work. My car is also an active, so that won't be the cause of any problems you guys might be having either**
Pete is a really cool guy too, and the list they have on their site of compatable vehicles contains a listing for the Q45 because of me
http://www.plmsdevelopments.com/consult_if.shtml
The problems with connecting via USB to serial ports are because the right chipset is required in the converter. (The PLMS cable is OBD 1 to D9 serial)
You may be able to get a converter to suit your connection needs that will work better, as long as it contains the FT232BM chipset in the connector.On the first page of this thread, someone posted a pic of the Belkin Part # F5U409-CU USB to serial adapter......
This has been known to work well.
A cable that has the compatable chipset, which is available in the US can be found here
http://www.cooldrives.com/usb-....html
I wonder if all the problems are related to connecting directly via USB?Maybe the output from the ECU doesn't agree with it?
Regarding the DataScan software, quite a few opitons are restricted in the free version. I saw the full version being used on my car, and everything worked.The possibility of knocking out more than 1 cylinder at a time is possible too. (We disabled 4 cylinders, and it kept running!!!)
As the cable was bought direct from the builders/programmers of Nissan DataScan, I have a full version of the software. I can't find it on my system, so I have just emailed Pete about getting the zip file sent to me again.I MIGHT set it up to be shared, provided it gets put onto notebooks that don't connect to the net. (I don't want to risk losing the software backup and support from these guys)
The harware/software should work on more than one car, and not need to be specifically programmed for any particular model. (Here's the list from PLMS, same cable, no special modifications to suit different cars) * AUS 200SX S14 (SR20DET) * AUS 200SX S15 (SR20DET) * AUS Maxima A32 (VQ30DE) * AUS Pulsar N14 (GA16DE) * AUS Pulsar N14 (SR20DE) * AUS Pulsar N15 (GA16DE) * AUS Pintara U12 (KA24E) * AUS NX/NXR Coupe (SR20DE) * JDM 180SX S13 (SR20DET) * JDM Silvia S14 (SR20DE) * JDM Silvia S15 (SR20DET) * JDM Pulsar RNN14 GTiR (SR20DET) * JDM Pulsar GTi (SR18DE) * JDM Bluebird U14 (SR18DE) * JDM Bluebird U15 (SR20DET) * JDM Skyline R32 (RB20DET) * JDM Skyline R32 GTR (RB26DETT) * JDM Skyline R33 (RB25DET) * JDM Skyline R33 (RB20DE) * JDM Skyline R33 GTR (RB26DETT) * JDM Skyline R34 (RB25DET NEO) * JDM '94 Cefiro A32 (VQ30DE) * JDM Avenir PWN10 (SR20DE) * JDM Infinity Q45 (VH45DE) * CAN '92 Infiniti G20 (SR20DE) * US 300Z Z32 (VG30DETT) * US Sentra B13 SE-R(SR20DE) * US NX2000 (SR20DE) * US NX1600(GA16DE) * US '94 Sentra B13 (GA16DE) * US Maxima A32 (VQ30DE) * US '93 Altima (KA24DE) * US '92 Infiniti G20 * UK Almera N15 GTI (SR20DE) * UK 200SX S14a (SR20DET) * UK Micra K11 (CG13DE/CG10DE * UK 1993 Primera P10 (SR20DE) * FRA 200SX S14 (SR20DET) * FRA '93 100NX 2.0 GTI (=NX coupe) (SR20DE) * GER Almera NX (GA16DE) * GER 200SX (SR20DET) * GER '91 300ZX Z32 (VG30DETT) * FIN 99 Maxima A32 (VQ30DE) * EDM 96-99 Primera P11 (GA16DE & SR20DE)
These listed are known to work, because the customers have given feedback indicating so.
I know many people won't bother clicking the link to the PLMS site, so I am just going to cut/paste some relevant info.
We offer the DataScan software for $AU30 with the interface.
It includes the following features:
* Compatible with Win98SE, Win2K, XP and Vista. * Real time monitoring of RPM, speed, injector pulsewidth, injector duty cycle, TPS position, AFM voltage, speed, idle valve opening %, IGN timing, coolant temp, battery volts etc. All displayed on nice pseudo-analog gauges. * Data logging on all parameters with cool inbuilt replay feature. * Read and reset fault codes * Active tests like “power balance” (knocks one cyl out at a time), fuel pump on/off, VCT control, temporary changes to values for coolant temp, IGN timing, AAC valve (for idle adjustment) etc. * ROM read * More great stuff!
What laptops will the DataScan software work with?
Most of our testing has been carried out on a P233 machine with 32Mb of RAM running WIN98SE although this should be considered an absolute minimum. It also works with Win2K/WinXP/Vista on a more capable laptop.One user has reported that he's running it successfully on a P166 laptop (64Mb RAM) under Win95!
Using a consult interface and DataScan software allows you to download the maps from your ECU.
Please note that 8 boxes appeared for the power balance when my car was connected, not 6 as shown here. (Pete must have had it hooked up to his R31 skyline for this screen capture)
