ponzy »
https://forums.nicoclub.com/ponzy-u50212.html
Sun Apr 08, 2007 5:12 pm
i got JAMIE's consult and was able to pull a code from that (worked for me for a couple min, got to try it again some time) there were ECU code 35 egr temp sensor and code 51. i was able to reset the ecu and code 35 disappeared but code 51 retained.
i did the plenum job (changed most of the underplenum hoses, bypass hoses, booster line and a lot more; DEATSCH-flushed rails and 6 injectors; 2 new injector from joe; changed knock sensors and harness; changed fuel lines from the filter-to-rail-fuel regulator; changed fuel pump and filter; cleaned the plenum, egr, TB, IAC, 2 months ago and was't that succesful cause i still have the "vibration" and additional symptoms: high idle rpm at start up (1250) then fluctuates at 450-750 constant at normal temperature 174 (ideal is 167.x i guess)
some of the tip-plastic cap of injector was chipped but was replaced with new ones from DEATSCH before replacing unto the rails. From these info, what do you think could go wrong? i did not changed the injector harness but they are all ok. it seems to be i need to send this car to a reputable shop and spend more dollars or just let it die out (i spent almost 3 g's already --- including some suspension parts which hasn't yet been installed like jeff's FSTB; tokiko sets; eibachs; FSB/RSB -- complete bushings; spl subframe collars and planning to buy SPL FUCA, RUCA, tension rods; jamie's usb-consult)Now, i am not sure yet if this' worth another dollars and just stop and cut my losses. i know this car was taken care of the previous owner and as the new owner for almost 10 months now, i've used the car no more than 4,000 mi and taken care of her a lot. but the maintenance thing is driving me crazy. the other side of me wants to go on and have this car fixed and the other is telling me to stop. PLEASE help me figure this out........i can get the money to fix this but i just want to be smart enough when to stop.......
thanks a lot.
Modified by ponzy at 10:42 AM 6/20/2007
