Group buy for Espilir Lowering Springs for G50s?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Some of you may recall a few months back when I had user "audiovisionY33" bring in a set of espilir lowering springs for the G50.
Due to some financial conflicts, I had to sell them to another person who I owed something to anyway.. Well, this person called me back, freaking out about how much he liked the springs. HE said that the ride was very nice, the look is great and overall he loves how it turns out, recommending to anyone...
Anyway, would anyone be interested in getting a set??? I probably need 10 sets to get the ball rolling and it may be a little wait since theyre being imported from Japan...
Price is going to be in the $300-400 range, no more no less. I have not narrowed down anything yet thats just an educated guess.
TBrack
Car: none
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hmmmm......aren't these the ones you thought were overly stiff and harsh? Maybe I am confused.
In any case, some good specification data wouild be nice if you can locate it.
If they didn't lower, I would be interested.
DoinkMobb
Car: 1994 Infiniti Q45 Green/Tan
1996 Subaru Impreza 2.2L wagon
I'd be interested. I'd also like to know by how much they would lower, and % stiffness increase over stock.
Q45tech
It would be honorable to take them to a spring dyno and actually measure their stiffness at the compressed height usually half free height.
Many aftermarket skip this step to proving linearity or non linearity.
Would help buyers select the proper perfect shock.
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
Pictures of the Q with the Espilir springs would be nice along with their suspension setup.
heywier427
Car: 91 Q45
Wes im sure your working on it, but im going to be the one to do it!!!!!
Had to!!!
im interested as well
91-q45
Car: 1991 infiniti Q45
id be in for sure.
elwesso
2007 BMW M Coupe
Im working on getting the guy to snap some pics... We'll see, its probably similar to the eibach springs..
Price is looking to be in the $380 range. I think I need 10 people to be in for the GB to work, since theyre going to be brought in from a container from Japan.
TBrack
Car: none
These maybe?
elwesso
2007 BMW M Coupe
Yeah those are it... OI have some more pics of the actual springs....
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Not too shabby, my bro should pick some up for his Q
91-q45
ok kwl, they work with stock struts right? how much of a drop are they?
elwesso
2007 BMW M Coupe
Its gonna be about an inch drop, theyll work great with tokico shocks...
I should be getting pictures sometime middle this week.
qship96
Car: 1996 Infiniti Q45
[QUOTE=elwesso]Its gonna be about an inch drop, theyll work great with tokico shocks...
Without knowing the spring rate of the lowering springs,how can you state they will work great with the Tokiko shocks?
elwesso
2007 BMW M Coupe
because the guy who had them said they were good... so thats about all I can say.
qship96
Scary!
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I'm interested and have some money.
newtoQ
Car: '93 Q45
Count me in for 1 set.
Q45tech
If the stock front spring's free length is 16.9" and the FSM says 146 pounds per inch and the unloaded weight is 80 pounds then the body loads the spring by 1000 pounds:
1000/146= 6.85" of spring compression mounted on an unloaded car on the street.
SO 6.85/5.85= 117% so the spring would need to be 17% stiffer than stock IF the drop is exactly 1.00000000000"
OF COURSE if there is a driver and passenger the spring will further compress depending on the weight of each.
What every shock you use would need to be 17% stiffer in all parameters to exact match the spring.
By coincidence or design Tokico Blue HP versions are 15% stiffer........close enough for the street but not the space shuttle.
Back in the 90's Eibach sold a spring kit with Tokico HP shocks all bundled together.
Unfortunately Linear springs are harder to find NOW and many make progessives since they are easier to design and fit in the oem space.Even Eibach's are progressive in the rear why I didn't go thru the math for rear.
DoinkMobb
The wife has given me the go-ahead to overhaul my suspension (the squeaking front passenger strut is annoying her). Definitely count me in for some springs.
one ton garage
Q45tech wrote:Would help buyers select the proper perfect shock.
Wait a minute... G50 owners have a multitude of damper choices now?!?! >HAHA<
one ton garage
Hmmm... I like how Q45 people still think their cars will spontaneously explode if they ran conservative aftermarket lowering springs with their stock struts, and even readily-avl aftermarket struts. Of course, there's no reason not to take into consideration the fact that springs like the Espelirs are produced by one of Japan's best suspension manufacturers and they don't just pump out crap that makes people's cars explode... as this particular product has been available in Japan for people to run on the same cars as we have here for probably a decade and a half. Ohhhh, but they're right hand drive... oh, yah in that case your lhd car WILL explode when you run these springs!
qship96
4 that I know of
tokiko blacks {OEM}tokiko bluesMonroweJIC coilovers
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
So what is the progress? Is this really going to happen. You can count me in on the group buy. I would like some for my 94 Q.
elwesso
2007 BMW M Coupe
The springs are ordered but they wont be around till march-aprilish. They are on the container but they have to wait until the rest of the container is full...
Somewhere around the end of Feb/early march i will start the waiting list
mtcookson
1992 Iinfiniti Q45
and much much more
Go Wes!
Rex
Car: None
How many did you order Wes?
TBrack
Car: none
elwesso
2007 BMW M Coupe
10 sets.
