cheapazz »
https://forums.nicoclub.com/cheapazz-u97627.html
Sat Oct 11, 2008 12:17 pm
OK, The stock grounding on most newer cars use very small wires to ground the system to the cars chassis and motor to make the needed connections throughout the electrical system on the car. The addition of larger wires placed throughout the car, i.e. ecu to batt., trans. to common grounding area, and other spots help the electrical system run more effeciently or "cleaner" and therefore help the car to run better, shift better, stereo seems more clear, etc. In essence the wires help to make a "better" connection for the sensors throughout the vehicle and therefore the vehicle has better response. SBD did alot of homework on the entire car to come up with these kits and you will receive a quality product that blows everyother kit away.
You will notice the difference!!!!!!
