feloniousmonk wrote:Spend the time to learn more about cars and electrical systems. Such things are nothing more than snake oil. But if you must, you can easily make a grounding kit yourself with car audio ground cables and ring terminals. All you need is a vise, sturdy wire cutters and a crimping tool. Foolish to pay what people are charging for "pre-made" kits. Just look for existing bolt/screw locations on the block and ground those to existing holes on the chassis. Not exactly rocket science. Measure twice, cut once, crimp, crimp, done. If you don't have access to a work bench vise, you can improvise with a C-clamp and some elbow grease.
The cost of the [proper] tools alone cost more that what we "snake oil" salesmen charge for these kits.
Grounding kits that ground the engine to the strut tower or firewall are funny and pointless.
Also consider that 4 gauge OFC wholesales for about $150 per 100' roll. Most audio shops will want to charge you $2.25-$6/ft for the good stuff.
With that said, how much are the eBay kits going for? $5? + $20 shipping?
10' 4 gauge OFC + 10 copper ring terminals + shrink tubing = $22 (wholesale).
That doesn't include assembling the cables. Usually what you get on eBay is Aluminum "4 gauge" (closer to 8 gauge) of generic lengths with super stiff jackets that melt under light heat.
