Ground Wire
Post all your Nissan electronics, car audio and stereo questions here!
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
The S14 has pre-threaded 10mm holes in the passenger side rear trunk flooor to the right of the spare tire cavity which are for the factory six disc changer you can use these for up to size (2 gauge) grounding points. just remove the paint 3/4 of inch around the bolt hole add a ring terminal to the ground wire and bolt down a 10mm flanged head with a lock washer/washer. Just don't over torque the 10mm beacause the break easily.
T.O 240sx
Car: 95 240sx w/ kouki conversion, Brembo brakes, KYB shocks, CAI, Infinity Sound System
hey Silvia2bthanks for the tips...i wish i could do that, but one problem... the whole truck is basically dynamated!... ill see if i can somehow get there without tearing off too much dynamate. do you know of any other places to ground in the S14? what about where the rear speakers mount, on the back panel... i know its painted there, but what if i could take some of it off?
PoorManQ45
Take a razor knife and cut off like a 2x2 or 3x3 in square wehre your grounding point will be
