grey smoke from exhaust
Dr.Doom
Car: 240sx s13 hatch
recently i let my buddy drive my car while i was driving behind him and i noticed that evberytime went full throttle, grey smoke came out of the tail pipe.
What causes that? worn rings?
240sx_sr20det_12
Car: 1990 240sx coupe
well more then likely all it is is incomplete fuel combustion....witch is no big deal or your ignition timing could be off. blue smoke is something to be concerned about.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
240sx_sr20det_12 wrote:well more then likely all it is is incomplete fuel combustion....witch is no big deal or your ignition timing could be off. blue smoke is something to be concerned about.
Not so much.
Unburned fuel is usually black. Oil burned in the combustion chamber will smoke blue, but oil dumped into the exhaust by leaking turbine seals will smoke gray.
Check to make sure the oil drain on your turbo isn't plugged or kinked. A plugged oil drain will over pressurize the CHRA, which results in oil pushing past the turbine seals into the exhaust, and in extreme cases, into the charge piping.
BoredDSM
FlatBlackIan wrote:
Not so much.
c
I always thought black smoke was oil burning and white smoke was antifreeze burning. Correct me if I'm wrong. If you burn oil it usually is black smoke.
IanS
BoredDSM wrote:c
Coolant will burn white
Oil turns diferent colors depending on the temp its burned at
If its burned with fuel in the combustion chamber, it will be blue, but if it just cooks on the walls of the exhaust piping, it smokes gray
unburned fuel will look black
Dr.Doom
cool cool, thanks guys, i'll look in that direction
