greddy type-s bov for real
gtune4
Car: toonah
ok, this valve is great. at least great for the price. but when i called greddy, after looking online, etc... everything i found was for me not to hook up the smaller lower nipple. thankx greddy. dont get me wrong, they have alright products, but i called them and this is what they told me. anyway, they were wrong. you CAN leave it open, but it is designed to have the turbo pressure that your wastegate is feeling pushing underneath the piston, so that when you remove you foot from the gas, or there is a pressure diff. between the two, recirculation, or blow off, occurs. note, the single line to vaccum will work for non recirc, but was giving me trouble with recirc. this is the reason i looked further into it. i would say go ahead and hook up both lines
top one to manifold press, smaller bottom fitting should feel the wastegate signal.
hope this helps someone, it helped me :ylsuper
ps. i hooked this up to eliviate the idle drop problem, which it did. too bad i am hooking up hks super afr tomorrow. this fixes this problem (hopefully)
VitaminT
Car: 93 240sx SE
Did you mean "feed" the wastegate signal?
deejayS13
Car: 2008 G37S Ivory Pearl, 1997 240SX SE Deep Fuchsia, 1989 240SX Silver Green Pearl & Dark Gray 2 Tone
dont ever smurf the wires on a super afr...thats not smurfy
gtune4
Car: toonah
smurfing is cool
as for what i say and what i mean, i say what i mean. the SMALLER NIPPLE ON THE BOV FEELS THE PRESSURE IN THE PIPING , it does not feed anything thank you
compression
The greddy type R valve I am using did not work at all with just the upper(intake manifold) line attached. When I ran a line to the lower nipple from the wastegate feed, it worked fine.Like he said, the greddy BOVs need pressure under the diaphram to overcome the spring, the vacuum, just breaks the seal and gets things started.
S13240
So for the type s and the type r the lower nipple needs to be hooked up for better response basically?
Cyberkreig
Car: 1993 Nissan 240SX SR
Wow. Thanks, I had no idea. Maybe cuz my instructions were in japanese. I'll try that tomorrow
compression
for greddy valves:upper nipple: intake manifoldlower nipple: tee off of wastegate feed lineits that simple.
If you use a bov like a blitz, that only has a vacuum nipple, then it may leak under idle. I had this problem before, I tightened down the preload screw all the way and the thing was still doing it.THe greddy uses a stiff spring that needs to be overcome by two pressures: the vacuum in the intake manifold and boost at the turbo.
VitaminT
Car: 93 240sx SE
Cool. That should help when I install mine this weekend. Yay no more SMIC.
gtune4
Car: toonah
Glad this post is helping, with as challenging as it was for me to build my own sr setup, i would have been nice if they would have just said "small nipple get pressure":icesangel
Cyberkreig
has anyone tried this yet? I looked at it this morning..
If you blow through the lower nipple it just comes out the BOV.. seems like an easy way to cause a vac leak to me. maybe the lower nipple is just for recirc?
gtune4
Car: toonah
i think you might be right about that.i disconnected my recirc right after i finished setting my super afr on a dyno, and i have mad probs. could be the afr, right now i cant tell. basically the prob is, only when lifting slightly off the throttle, the motor stumbles, backfires, acts shady. boosts well and the a/f is strait. anyone got any hints on this hks ****.
by the way, some guy at altered atmosphere reccomended that i take my car to this place called turbo tune, he new cars etc.. but had never seen the super afr nor did he know how to tune it. very interesting.
gtune4
Car: toonah
okthe second nipple might be for bypass. w/o bypass hooked up there were probs. when i took off the second nip, and no bypass, works fine. also, i think that if you run any kind of bypass, you can't have the idle stabilizer on the afr on.
gtune4
Car: toonah
nothing to do with bypass or not, just too much fuel.
Big Perm
If you search around a bit you can actually remove one of the springs from the BOV and then, using a vacuum pump and gauge set the BOV to open at the right amount of pressure. I only have the top "nipple" hooked up with a vacuum line and I have no problems
caliracer240
Car: cars and chicks
yea much like "big perm", i have only the one nipple hooked up to vacuum and i have no problems at all except for a little back fire/pop when i let off the throttle at high RPM's. But i love it!!
240SXer
Car: 1995 240sx SE (2jz powered)
I'm lost. Okay, my Type S has 2 nipples, plus the big bov part. The upper nipple is hooked up to the intake near the throttlebody (if I remember right) adn the lower one is hooked up to nothing. I leak under high boost pretty bad. And mine is pretty tight. What is this about me hooking up the lower one to the wategate? What will that do? I don't get it. Will it adjust it with the boost to make it hold better when it's actually boosting?
VitaminT
Car: 93 240sx SE
If I remember right it helps open the valve, but I am not sure. Some people just cap the lower one off. Also not that some of the ports on the TB do not receive boost and vac, only vac. That might be it. My BOV runs off of a nipple on the hotpipe.
240SXer
My lower nipple on the bov isnt even capped, it's just empty, should I cap it? Hook it up to the wastegate?
VitaminT
Car: 93 240sx SE
I am not sure. You can try capping it and see what it does. Have a buddy check for leaks as you rev and let off. If it is still a problem just hook up a line from the wastegate signal.
I and I lied about getting my top signal from the hotpipe. I was a little confused at the moment. Mine pulls from the TB.
240SXer
Alright, i'll cap it and see what it does. I want to know the point of hooking it up to the wastegate though. If i'll help i'd like to do that.
compression
OK OK, dont cap the lower (small ) nipple. As the diaphram in the BOV moves up and down it will displace air in and out of that nipple. BUT, if you blow into that lower nipple you will notice that it is leaking out somewhere. If the small nipple is capped, then the air the diaphram displaces when it moves will all be forced out that small leak hole (where ever it is). WIth the nipple uncapped, the displaced air can travel in and out of the nipple, which is a more unrestricted path. So, in threory, your BOV should be more responsive with the lower nipple open to atmosphere.When the throttle slams shut under boost, the sudden increase in vacuum from the intake manifold will be the only force overcoming the spring & opening the valve (well, and the pressure on the plunger from inside the pipe, but lets not think about that).
By hooking that nipple to the wastegate feed line(optional), then when your throttle plate slams shut under boost, the upper BOV nipple sees a **** load of vacuum and the lower nipple sees a ****load of boost, this pops the bov open until there is not enough pressure difference to keep it open, then it shuts.
When should you hook up your lower nipple??? Heres my 2cents: when it works better that way.Seriously, use the lower nipple if you have to have a lot of preload on the spring to keep the valve closed at idle, the added push from the boost coming in through the small nipple will help overcome this spring force when the time for blow off occurs. Try both ways, see what works best for your setup.
Also your valve should not be leaking at high boost levels (unless it is defective or hooked up wrong). During these periods, the whole system is pressurized, even the intake manifold. Since you have a line going from the intake manifold to the upper(larger) nipple, then that line is pressurized too, forcing the valve close (along with the spring force).
compression
Also, if you do hook up a line to the small lower nipple, dont worry about losing boosted air through the leak that you found when you blew on that nipple, it is negligable, you most likely lose more air through the silicone couplers in the system.good luck, let us know what happens.
VitaminT
Car: 93 240sx SE
Dang that was very informative. Thanks.
caliracer240
taught me a few things.... thanx!
240SXer
Ya, it was..
Mine does leak under boost though. I don't want to buy a new one. I'll buy a new spring if I can find one. It's hooked up correctly. I can provide pix if you wanna see. But will hooking up the lower one possibly make it hold shut easier while boosting? Maybe preventing it from leaking under high boost?
gtune4
Car: toonah
how much boost are you running? im at ~11.5 lbs and mine doesnt leak. i dont think anyway. how could you tell. is it the same as when you have a piping leak, cause i know what thats like.
240SXer
Ya, it's the same as when there is a boost leak. It sux... I've lost races because of it
caliracer240
ok i have a nipple on my hot pipe that runs a tube to my W/G acuator, do i "T" that off and run it to the bottom smaller nipple of my type-s??
gtune4
Car: toonah
thats what i diddo it before your boost controller
