Yes the red line in the picture should work. THe beauty with BOV's is that you can just try stuff, there are no serious consequences if you hook something up wrong, and the hose&fittings are super cheap.
Good point in the last post about the pressure acting on the cylinder itself. In most cases the spring is more than enough to overcome that force.
240sx'r what psi are you running? DId i read that you are pushing that little turbo to 15psi? man, thats a lot for the stock S13 T25. The type s is probably too weak for you, especially if you are running that kind of boost. Try the type-r, thats what I am using and it is more stiff than the type-s (i tried both). Or you can hunt around for a new spring for it, dont know where though.... IF it is leaking at high boost, then definitely dont hook up the lower nipple, that is just one more force trying to open the valve whne you are boosted.
240sxer, you want me to make you a plate out of aluminum? I can ship it out on monday if you paypal me $10 if you want it. You have to email me at
[email protected] because I wont be on this forum again till next week.
