msaskin wrote:Then you should be using a proper tuning tool, not a hack-job piggyback.
The e-manage is essentially a glorified S-AFC.
~matt
The same could be said for the AEM system by someone that owns a Motec.
There is always something bigger and better... it's just differentiating what you can afford, and what you want/need out of the system. For most people the AEM is overkill, and for some the AEM is perfect, and for a very few the Motec caliber system is the only alternative. Just because someone utilizes something within their means does not make it inheriantly bad. It might not be ideal, but often times life isn't ideal.
