Got some front-end damage that I need to fix, need advice!
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
Had a chance to tear down my front end and see what I'm dealing with, and I'm not sure how to proceed. Most of the damage was to the headlight assembly (has been replaced) and the front radiator support. The support is all there, just bent up, and I'm not sure if that is something a shop would be able to pull out and make true. Initially I wanted to replace the whole front radiator support, but I don't know how to handle the tack welds that keep it on the frame (I also don't have a welder at my disposal.
So I'll let the pictures do some talking, and I'll welcome any and all advice on how to get this fixed.
Thanks in advance guys! As of right now, I can get a clean radiator support by Friday, I just have no idea how to actually put it on.
Heavy
Car: 1992 Mr.Two, 1996 LS4HUNNID, 1999 Appliance on wheels.
they are easy to take off, just time consuming. Make sure you scrape off all the sealant and drill out all of the spot welds, and yes they make a drill bit specifically for it. Ive used one before and it made it so much easier. If im correct theres also a few bolts that need to be removed as well.
http://www.summitracing.com/parts/BRC-13224/?rtype=10
or just order a rad support and start calling up local bodyshops and get quotes for removal and install. Its prob going to be a few hundred dollars.
here i found this that you can use for reference for removal.. just scroll down
project-silvia-uber-build-thread-t395603-80.html
if either of those two options dont work for you then buy a BFH "big f***ing hammer" and some rope. Tie it to a sturdy tree and start pulling and beating lol
Loki
Yep, I got two of those bits already. Time consuming I can do (yay spring break), just can't do any welding myself. Thanks for the reference, that's just what I needed.
