Welp Now only working one job
I decided to attend summer school at jccc this year, so don't expect alot of updates. I have set a new goal and thats by the end of december 2010, I plan to have my car ready for paint. Here is my mental time line 1st Finish engine and transmission 2nd s15 conversion/sideskirts+rear bumper 3rd roll cage/fuel cell 4th suspension/wheels
Tension Rod Dillemma with S15 Radiator support
So this is a pic of s14 tension rod "on top" vs s13 tension rod "on bottom" The main difference is that the s14 tension rod is longer, and will reach to the s15 radiator support.
The S14 tension rod "left" will bolt up with no problem to the s15 radiator support, but the S13 tension rod "right" would have to be modified if I decided to use the s13 tension rod
If I went with the S14 tension rod "top" then I would have a problem with bolting it to the frame rail because it's shorter than the s13 tension rod "bottom"
S13 tension rod to s13 frame rail "obviously no problems."
S14 tension rod to s13 frame rail shorter thus not reaching to the other bolt hole. In the end I will most likely have to modify either the s13 or s14 tension rod either way to make it work with the s15 radiator support.
I decided to spray some rustroleum where ryan welded at, so that it wont rust over a period of time.
Plus it's probably a good idea to spray some in this area before I have him weld these brackets back on.
I decided to replace all my freeze plugs, You have to be very careful doing this normally this is done when rebuilding the engine. As you can tell, I popped my first plug right into my engine dammit.
Sooooo... I decided to remove my valve cover, so that It would be easier for me to take out some freeze plugs. I started by removing the coil packs with a 10mm socket wrench.
Then remove all 13x 10mm bolts holding the valve cover in place, I started with the middle bolt first then proceeded to work my way around the valve cover. "Remember don't forget to have a ziplock bag in hand for all the bolts"
I then removed this hose that connects to the pvc valve, I believe thats what it's called.
Then give it a tug to break the gasket seal and remove the valve cover.
OMFG! This is absolutely unacceptible, I really want to rebuild my engine although it is currently not on my top things to do, so what i've decided to do is simply. Do what I had intended to do FIRST then go back and see if it's in my budget/time to rebuild it or not. Sooooo moving on...
I managed to find the freeze plug, I accidently popped into my engine.
What you want to do is SLOWLY tap one corner of the free plug with a flathead screwdriver and hammer until it looks like this.
Then use a combination of needle nose pliers and normal pliers to pry out the freeze plugs.
Once the freeze plug is out clean the surface area where your going to put the new freeze plug in and use a combination of a 21mm socket and hammer to "seat" the new freeze plug in.
In order to get to one of the exhaust side freeze plugs I needed to tap out the oil tube, I used a large flat head and a hammer to tap it out.
Moved on to install my Nismo motor mounts.
The Nismo mounts did not come with the brackets that are on the OEM ones, so you need to remove the brackets that are on the OEM mounts and install them to your Nismo mounts.
"Instake side" bracket installed on the Nismo mount.
Nismo mount "intake side" installed onto the motor mount bracket, you need a 14mm wrench.
Nismo mount installed "exhaust side" onto the motor mount bracket, you need a 14mm wrench.
ATI Super Damper Install! First I just used the supplied bolts to just hand tighten the p/s pulley to the crank pulley.
Then thoroughly clean your crankshaft and apply a small amount of antiseize.
Theres only one way to put the pulley on and unlike the OEM crank pulley the ATI crank pulley is a tight fit, so to get it started I used a rag on the pulley then placed a board and hammered it till it was on securely.
Then used the impact gun to completely "seat" the pulley in place, I used a 27mm socket btw.
Then I threw the new belt on thus concluding my day.
