Got my ST Sways...
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
I know zilvia has a decent writeup on how to install the bars, but from you experienced people, are there any tips I should know before hand?
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
its a *****.
240marcuSX
Car: E34 525i
E46 M3
my advice to you bro is to use the stock bolts that holds the bar to the underbody. maybe yours is different, mine is an rhs13. but anyway. the stock bolts are stronger and smaller in overall diameter so they arent such a tight fit.
sr20power
Car: S14 Zenki
i didn't have too much trouble w/ the rear sway bar, but the front is where i spent most of my energy with. you might want to have some kind of spacers or about 15 to 20 washers for the rear. i had to add extra space because the bolt they supplied wasn't threaded far enough and also comes very close too the heat shield at the hump of the bar.
i'm with marcusx........for the front i ended up filing down just enough to be able get the bolt thru. if you try to force it in there you end up like me , stripping the thread. good to have a friend whos a mechanic and has a shop.
total time installing both bars = 5 hours but well worth it.
Dori Dori
Car: Cars of course
They were easy for me to install...if one side was more difficult, I'd say the front would be it. Get some jack stands or something to support the bar while bolting it up. Makes things much easier.
UncleBen
Thanks for the info. I am definately not looking forward to putting them in, although I am looking forward to see how much of a difference they make.
C-Kwik
When you install the brackets that hold them up, make sure you bend them slightly so that the bolt holes line up correctly. The 'D' shaped brackets on mine were not closed up enough so I ended up cross-threading one of the bolts.
UncleBen
Awesome thanks
TurboKA37
i have whiteline sways but i imagine installation should be similar. i didnt have any problems with the install as i can remember but the most difficult part was the linkage on the front sway but i think the linkage is different on the ST sways. installation will be much easier if you have a friend to help hold it in place as you bolt it into the frame with the D-Brackets. i did it by myself and it probly took about 3 hours total. also make sure you have the D-Bracket and bolts for the rear sway bar if you didnt have a stock sway bar. im not sure if the ST sways include that.
Exar-Kun
Car: 2005 350Z
mine took 37 minutes with a lift and some air tools.-chet
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Exar-Kun wrote:mine took 37 minutes with a lift and some air tools.-chet
$H0W0FF:D
-Dan
UncleBen
i need a lift
Dori Dori
Car: Cars of course
Nah, they should be preloaded anyway. Use ramps.
TurboKA37
i just used jack stands, its hard with the suspension not being preloaded but you can do it
Dori Dori
Car: Cars of course
Ease of install wasn't my motive for preloading the bar.
UncleBen
I put the rear one in today, it was cake. I sense some understeer more than normal, since the front is stock still and the rear stays niiiiice and flat. Its great!
Dano
word, so talk to me about your stock sway;)
-Dan
skatanic28
Car: 96 240sx
95silviase wrote:I put the rear one in today, it was cake. I sense some understeer more than normal, since the front is stock still and the rear stays niiiiice and flat. Its great!
push a little harder and enjoy the snap oversteer too;)
youngturk
Can ST sway bars be painted, say with caliper paint, engine enamel paint or the likes? Does the twisting applied to the bars cause the paint to peel away? Has anyone painted their sway bars in any way?
Dano
why would u want to paint your sway bars?
-Dan
youngturk
Well, because I want to.
I just wanted to ask if anyone had done it and, if so, how. Thanks.
Dano
well, you could powdercoat it (longest lasting option) or u could try an enamel. as always when painting anything, prep is key to make it last... good luck with painting your suspension
-Dan
89240sxdude
Car: carpentry
putting mine in wasnt too bad but i had a lift and air tools. i had a little dificulty lining up the D brackets and one of the bolts stripped out on my first test drive and bent the d bracket back but i impacted a larger bolt in and it held great. so just make sure your bolts arnt crossthreaded and make them as tight as they can possibly go because there is no way to get to the inside of the frame to replace the nut or bolt, on the front of my 89 anyways
Exar-Kun
Car: 2005 350Z
alignment racks own.(lift it and have it preloaded..)-chet
itssr20
would having the car sit on ramps work for installing sways?
Dori Dori
Car: Cars of course
Yes! Ramps work perfectly!
UncleBen
I finished them both and honestly they were cake. Very straight forward. Suspension Techniques instructions and supplied hardware was great as well. Some of you terds had me worried, but it was easy!!!!! :pface
Dan, yes, we can talk about my stock sways ;)
UncleBen
itssr20 wrote:would having the car sit on ramps work for installing sways?
I doubt it. I mean it would work, but you pretty much have to take the wheels off to change the sways. Plus if you just use jack stands, that takes the weight off the entire suspension, allowing it to flex some if you need it to (which you do).
So basically no, using car ramps wont work.
Dori Dori
Car: Cars of course
That's not true. I used ramps when installing mine...I never had to remove the wheels...and your supposed to have the suspension preloaded when installing swaybars.
IlIkEmYz
Car: 06 Z
i still have my st bar under my bed. but they should go in by the end of this month
