Let us know how that goes...maybe that is the true solution to the problem...ClutchKick wrote:I had new struts put in on mine while it was being prepped for sale on our lot... it obviously did not fix the problem...
we are going to try the "Closure Assembly" and see if that does the trick
The Factory struts are too weak, so replacing them with the same weak strut will not work. Burtman's kit is just two stronger pistons. Change one shock and the trunk will open about a foot. Replace both shocks and the trunk will open all the way.ClutchKick wrote:well see, its to try...
my rear trunk struts were just replaced and it doesnt pop up enough to clear the closure device...
oh well...
