xdreamz wrote:I know a rep w/ crane, and says they can or have designed cam and cams for 240 that with nothing but a ecu chip can net up to a 40% gain, but at that rate may not be dependable, so i would say about 20% gain should be possessable with under 800
i would poke around and see what and who can do it
http://www.negative-camber.org/jam149/240cams.html
Jim Wolf Cams - by no means a sucky tuner or manufacturer, unless Crane Cams makes cams that can generate enormous HP out of thin air.
Bone stock dyno 125 RWHP
He dynoed 149.7 RWHP with custom 3" alum intake, Apexi N1 dual, JWT cams, Castrol Syntec 10w30, 25deg BTDC, 17" SSR w/ Yoko A032R 235x40x17, 4th gear pulls NO ECU
25HP from intake/exhaust/cams
Dyno #2 same mods but with JWT ECU - 161HP (11HP difference w/ ECU)
I doubt your 40% is credible, that would be about 60HP more than stock (155HP) about 205HP crank....probably 180ish RWHP w/ 15-17% drivetrain loss. Thats if the 40% is calculated at the crank.
I doubt even 20% from the cams alone, remember he had intake/exhaust and all he netted was 25HP. Divide it up evenly among the 3 mods its about 8HP each. You could say that the intake/exhaust both make 1HP each and the cams make 23HP, but I doubt that is realistic.
Maybe you can ask the crane rep to make a group deal for 240sx cams that make 40% gain w/ an ECU alone. I would be the first in line to get a set.
