EZcheese15 »
https://forums.nicoclub.com/ezcheese15-u102.html
Thu Apr 03, 2003 12:07 pm
There is no 4th and 5th gear sensors. There is only two limiters on the car. One is a speed limiter. The other is a rev limiter. Your car shuts down in 4th gear at less than redline because of the speed limiter, not the rev limiter. Same goes with 5th gear.
The only way around it is to cut the speed sensor, but then you also loose your speedometer too. Either that, or get a JWT ecu.
As for racing the Honda....Did you *see* the engine? Did you verify it was the stock D16? I've had plenty of Honda gurus claim they had basic bolt-ons, but what they don't tell you is they are basic bolt-ons on a B18, and their car weighs 1600 lbs.
It doesn't suprise me one bit that a Honda beat you. A 240SX is not exactly what I would call quick. And a tastefully modded Honda *is*.
