^ very helpful, but I think the best recommendation is use that camera to take and post up plenty of pics of hot, scantilly clad womenz...Razi wrote:The aperture is a diaphragm that controls the depth of field in a picture.
Larger aperture (smaller number) gives you a very shallow depth of field, a smaller aperture (larger number) gives you a greater depth of field (more things in focus).
For instance, I focused on my horn in this picture, and I used an aperture of f/2.0
As you can see, the focus drops off almost immediately before and after the horn.
In this picture I focused on the motorcycle's headlights, and used an aperture of f/4.0
Here you can see more things are in focus, and doesn't drop off as quickly as when I used f/2.0
In this one, I focused on the CTS Coupe and used an aperture of f/22 (The smallest aperture on my camera)
Now everything is in focus, even the tree in the waaaaay back.
Now, a larger aperture will let more light into your magical light capturing device, and a smaller aperture will let in less.
You need to adjust for this difference by changing either the shutter speed of ISO on the camera to get the right exposure.
I hope that wasn't too confusing.
I remember trying to understand how the heck a camera functioned and the subject of aperture confused me the most.
Taking a photography class helped a lot.
I was just doing that. The camera actually wouldnt autofocus the way I wanted it to. Definitely going to dedicate a lot of time to this thing.PoorManQ45 wrote:Please learn how to manually adjust your camera.
Figured as much, dont really see how that classifies it as a filter though.snwbrdr435 wrote:The clear uv filter will protect the front of your lens from scratches etc.
Neato!DJBeasy wrote: Razi, seriously thank you for that tiny tutorial above. Gave me a huge jump start on understanding this thing. Yes, they are pictures of junk but the fact that I took them with an understanding of the process makes me feel fuzzy inside.
Pick up a speedlite. The Nikon SB-80DX or Vivtar 285's are cheap. I have a couple 430exII's but just ordered a 3 of the sb80dx's because of how cheap they are and the fact they have sync sockets and optical sensors. Also have a 1/1000 duration at full power.DJBeasy wrote: Does anyone recommend picking up an external flash? The T2i has the built in pop up one and its pretty bright. Havent used this thing outdoors or at night yet though so not sure if it will suffice.
