OwnerCS wrote: Somehow a strange coincidence, the Stillen bar came from a good running Q that experienced a similar transmission failure. The owner donated it to charity (the crusher) and sold off the enhancement parts..
I wouldn't buy it...OwnerCS wrote:
There was a nice 94 model there in the spring that looked to have been well cared for that crashed into the read end of another car.. All fluids on that car were clean..That one could have been worth the hassle of trying to pull it myself..
Classic signs of Infiniti manufactureres procedure to dealerships when they replaced early Q transmission after failure while still under warranty.Many times the actual job title of "replace transmission" did not show up on service records, it was listed as a job or campaign number that Infiniti issued to deal with the common issue back then, and the campaign included a new transmission with pan that had a drain plug {original early Q left factory with no drain plug on pan},filter and add on cooler as you described.OwnerCS wrote:The transmission did have a drain plug and it seems there was a small line cooler beside the pan. Does that indicate original transmission replacement?
Ah ha! That explains it..qship96 wrote:Classic signs of Infiniti manufactureres procedure to dealerships when they replaced early Q transmission after failure while still under warranty.Many times the actual job title of "replace transmission" did not show up on service records, it was listed as a job or campaign number that Infiniti issued to deal with the common issue back then, and the campaign included a new transmission with pan that had a drain plug {original early Q left factory with no drain plug on pan},filter and add on cooler as you described.OwnerCS wrote:The transmission did have a drain plug and it seems there was a small line cooler beside the pan. Does that indicate original transmission replacement?
Hate to sound like Maxnix but he means external filter (Not the one that sits above the transmission pan).qship96 wrote:...filter and add on cooler as you described.
4600 or thereabouts, including install as I recall. I only got around 20k miles on each used transmission, so it just seemed like the next logical step. Got tired of the hassle of it all. I've had this one for 5+ years.Infinitiguy19 wrote:What did that cost if you don't mind me asking?
johnwhitmire64 wrote:Just took out a Mustang GT on my way to Taco Bell for lunch... ***hole called me an oldman, making remarks about my Q. At the light, after I passed by him, I asked him how it felt to get b****-slapped by an old man in a 4door... LOL
Well If I was to spend $3K just for the OEM A/T or go with the best A/T available I would go the latter route. I assume you drive the 400 HP beast like you stole it and it has held up for this long!johnwhitmire64 wrote:4600 or thereabouts, including install as I recall. I only got around 20k miles on each used transmission, so it just seemed like the next logical step. Got tired of the hassle of it all. I've had this one for 5+ years.Infinitiguy19 wrote:What did that cost if you don't mind me asking?
No issue after all.. It was apparently some moisture that built up in the mufflers after some short interval runs during the winter. The whole noise issue turned out to be caused by left side chain tensioner being clogged by some RTV fragment. At low RPM the tensioner allowed chain slack to slap the underside of the upper head guide to make noise. Now I understand the purpose of the upper head mounted guide -- that is to make noise when the chain gets too much slack as to send a warning..Q451990 wrote:Damn!
When this happens to me I'd be mighty tempted to do the 5 speed swap. Of course I'd never get around to it and have a dead Q in my garage for 20 years...
Did you ever get the suspected head gasket issue fixed? I don't remember reading about it, but I could have missed it.
Heath
Nice, sounds like you dodged a bullet... At least for now. These cars amaze me...OwnerCS wrote: No issue after all.. It was apparently some moisture that built up in the mufflers after some short interval runs during the winter. The whole noise issue turned out to be caused by left side chain tensioner being clogged by some RTV fragment. At low RPM the tensioner allowed chain slack to slap the underside of the upper head guide to make noise. Now I understand the purpose of the upper head mounted guide -- that is to make noise when the chain gets too much slack as so send a warning..
The engine really runs as good as it looks..
That was before the A/T failed so now the bullet finally hit him.johnwhitmire64 wrote:Nice, sounds like you dodged a bullet... At least for now. These cars amaze me...OwnerCS wrote: No issue after all.. It was apparently some moisture that built up in the mufflers after some short interval runs during the winter. The whole noise issue turned out to be caused by left side chain tensioner being clogged by some RTV fragment. At low RPM the tensioner allowed chain slack to slap the underside of the upper head guide to make noise. Now I understand the purpose of the upper head mounted guide -- that is to make noise when the chain gets too much slack as so send a warning..
Infinitiguy19 wrote: Well If I was to spend $3K just for the OEM A/T or go with the best A/T available I would go the latter route. I assume you drive the 400 HP beast like you stole it and it has held up for this long!
Does it shift as smooth as OEM though? Because that might be the nail in the $4.6K coffin for me.
I'm confused... He did lose his transmission?johnwhitmire64 wrote:Nice, sounds like you dodged a bullet... At least for now. These cars amaze me...OwnerCS wrote: No issue after all.. It was apparently some moisture that built up in the mufflers after some short interval runs during the winter. The whole noise issue turned out to be caused by left side chain tensioner being clogged by some RTV fragment. At low RPM the tensioner allowed chain slack to slap the underside of the upper head guide to make noise. Now I understand the purpose of the upper head mounted guide -- that is to make noise when the chain gets too much slack as so send a warning..
