Cone Junky wrote: realize that putting in a used, illegal, turbocharged motor from Japan does not solve everything.
It does too.
Seriously though.
Look into a stoker kit, the KA already cant rev, might as well make as much low down as possible. Then have the head built, fully built, with a full port and polish. With the motor all squared away research manifolds. Individual throttle bodies might be a good idea, or a custom plenum. General consensus says that much of the restriction in the KA is the intake manifold so choose carefully. Also remember not all intakes are created equal, some will shift the powerband up, some will help with torque production. Keep your goals in mind so one mod isnt fighting another. A good exhaust manifold is also a good idea, and just like the intake, different designs help with different things.
You should also decided how to tune it, full standalone, piggyback, daugheter board, or rom tune. There are many options, and Im sure one will suit you.
You will also need to improve the ignition system with some sort of aftermarket coil.
All that being said, building an NA motor is expensive, and if all out power is your goal, there are far better options. Do the research, settle on a budget, and know what you want.
