WHAT??? damn man the rear is a 12mm. I think you need to get off the comp and do some physical labor...
With a 3/8 drive and a 12mm one should have no problem. These bolts are nothing, and I would say dont attempt at removing anything like a caliper bolt or any suspension bolts, these are aged on nice and tight, unlike the covered strut tower bolts...
Dont mean to be an a**, but man hehe. I suppose you could bust out the rubber mallet then hammers in incremental sizes.
You might like to invest in a compressor and 1/2" and 3/8" impacts, I think that was stated previously.
Im not a big man at 5'11 140lbs but Ive only had one bolt beat me, and it was due to lack of tools and stupidity. It was a very torqued on caliper bolt on my gfs 240. I ended up not bringning a breaker bar nor a hammer and attempted to pull it off with a 3/8" drive ratchet only. It beat me bad though and tore up my neck muscles pretty bad, laying me out for a week - 10 days, immobilized.
I got my front spindle bolts off by hand even though they where 1/2" impacted on to 285 ft/lbs +.... I say plus because the rental torque wrench was a 1/2" and I was using an adapter to 3/8" and I wanted to see how tight they where on after fighting it for a bit over an hour... for one. I kept incrementing the torque on the wrench and got to 285 ft/lbs when the adapter sheared clean off.... I did manage to get all 4 of the bastards off by hand with a pipe a ratchet and some pb (it took busting 2 x 3/8" drives a wrench on both ends and the adapter to do so). Modifying the struts for the koni inserts was a breeze after that.... It was almost like taking a break.
Put some a** into it
