glove box, before & after
Nathan
So what exactly IS under the cloth? Is it just smooth black plastic? I might jsut rip mine off, hit it with some 400 grit sandpaper and leave it as a "matte finish" glovebox :) The Nathan cares little about looks but HATES that fabric crap. Besides, its weight savings :D
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Mine wasn't smooth plastic
It was black; but I think from the material being in there so long and the glue they use it's got ridges in it..
In this pic you can kinda see what i'm talking about:
Nathan
Hmmm, I MIGHT be able to sand through all that, sure is ugly though! Thanks Fuzion :)
PacManVR4
What do you want for the cat......Anyway, I hate our window cranks, Waser/turn signal controls and clovebox handle. They are all nasty looking. I bought some new window cranks but I have no idea what to do about the waser stalks and the door handle. BTW that would look nice in some Bride fabric.....
Mr1der
Acura did the same thing with the second gen Tegs. They didn't do it the glove box though (I still wonder what they were smoking on that one).
My door panels however had the tweed and they were actually starting peel off the car, so I just ripped them off. it leaves adhesive residue that's a pain in the *** to get off, but looks soo much better after some cleaning and a coat of protectant:)
I'm betting Nissan threw the tweed over the vinyl on the doors like Acura did.
BoostFab
Car: S13cp, S13fb, S14z
Nathan wrote:So what exactly IS under the cloth? Is it just smooth black plastic? I might jsut rip mine off, hit it with some 400 grit sandpaper and leave it as a "matte finish" glovebox :) The Nathan cares little about looks but HATES that fabric crap. Besides, its weight savings :D
once you rip off the fabric layer, reveals the old yellow gunk of foam and glue. give it some good sanding throughout to get rid of the yellow stuff and you could probably be happy as is--without rewrapping, since the plastic is somewhat black.
Hellion240sx
Car: 1992 240sx se
to both of you, GREAT JOB!!! both look impressive. and to think, you did it yourself! how long did it take you to complete this? did you use a heat gun or anything? or just glue and let it dry? how long does it take to dry? was it expensive? just throwing in some "whatever questions" (in case others are wondering too) to do the door, how do you... well im guessin you get a big enuff piece to cover up the whole door then glue it on then cut... or how does that go? thanks again
p.s. you should do a step by step write up.
peace
marshun
im starting to think you could possible spray it with some cloth spray?
mandoz85
Step 1: remove your glove box from car.
mandoz85
Step 2: Remove all screw from backing of the glove box
mandoz85
Step 3: Start at a corner and begin to peel off the old fabric. It should come off in one piece. After that you can sand the face of the glove box to remove any of the left over material.
mandoz85
Step 4: Take the old fabric and use it to trace an out line on the new fabric of you choice. make sure to make the outline a little bigger, that way you have more room for mistakes.
mandoz85
Step 5: test fit the fabric that you cut, make any cuts that are neccesary. Spray the glove box face with some glue. place the fabric on the glove box and strecth it to remove any wrinkles. flip the box over and spray the glue on the edges of the box. now you just fold any extra fabric to the back side, to hold it in place I used some small staples. let dry.
mandoz85
Step 6: You are now finished, go put it back in your car and injoy.
SloS13
I did the same exact thing to my glovebox a few months back. Hardest part is the curved part behind the handle. good jobs guys!
I also re-did my headliner. made the car look like new...wel....looks a lot better anyways
BoostFab
mandoz85 thanks for the contribution to the how-to.
although, the "All Purpose" glue might not hold-up over time (i could be wrong ;) ). i would go with a spray on glue that's more specific for the application.
the result will be much greater quality if we spend time on it
180fan
Car: 89 fastback
Awesome results guys! I think I'll get around to doing that during my spring break along with the install of my 180sx windows. hee hee hee
Thieu
I did this a couple of months ago, one day when I was bored. I used real leather that my mom had lying around. I also went ahead and cut out pieces and had her sew me a real leather shift boot. All free. Me likey free...
The same day I ripped off the carpet stuff on my door panels and was going to make leather replacements, but I got lazy, plus they look fine the way they are.
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
SloS13 wrote:I also re-did my headliner. made the car look like new...wel....looks a lot better anyways
Have any pictures of that? I'd like to see how good it looks.
Nathan
BoostsFed wrote:mandoz85 although, the "All Purpose" glue might not hold-up over time (i could be wrong ;) ).
You could also use some slow setting epoxy painted on with a foam brush you plan on throwing away :) West Systems most likely makes exactly what I'm thinking of.
element240
Car: cars
anyone know how to remove the cloth from an s14 door panel? i have a 95 and the cloth looks like shiet! btw, awesome job u guys!!!!!
fuzion
I tried to do the door panels.. funk that! I think a heat gun would help.. what a pain in the arse.. I got the main part of it done but the hard part was getting it to stay in the little "U" shaped groove where the stock material was tucked in...I ended up putting the stock stuff back on. I will try it again soon..
goomba240
Just go to the junkyard and pickup the glove box/door panels outta an LE. I got some in my '89. They got suede instead of that burlap crap. Very very nice lookin..
Hellion240sx
Car: 1992 240sx se
just wondering is there any specific sand paper grit your supposed to use??? and headliner pix!!! we want them. i want to do that in fiberglass really but if i cant i am gonna do it in vinyl.peace
o and thanks again for the step by step
peace
JimLecesse
Car: 1992 240sx Hatchback - SR20DET
looks great guys.. i was bored the other day and i ripped the ugly fabric off my S13's door panels, now im stuck with the even uglier brown cardboard look with the foam/glue crap stuck all over it.. i think im going to try to sand that all off and then maybe hit it with some thick bumper paint or somethin black.. anyways does anyone have pictures of their door panels redone, i need some ideas
Hellion240sx
Car: 1992 240sx se
did you ever get pix of the headliner?
Nautious1
Car: Cars, Sports
great write-up! I plan to do the same to my car soon.
marshun
hawaii eh? what a coincidence. :)
Hellion240sx
Car: 1992 240sx se
pix of the headliner??? pix of the headliner???
pssshhhtt "pix of the headilner will you please report to the forms" :)
lenso
Car: 1993 240sx hatch
for those who got actually did this, how did you do the part under the handle where it dips in? i can't get it right cause it tends to wrinkle.
