I'll confess, though, that I haven't been able to prove this hypothesis via the FSM documentation. There's nothing I can find that shows the actual location of the switch. But this ghost alarm problem also looks like it hits the G37, for example this post on Reddit:
https://www.reddit.com/r/G37/comments/w ... going_off/
...and that post also says the hood switch for the alarm is in the passenger side hood latch.
It should be 10 minutes of work to confirm, though:
- Turn ignition on, hook up the Foxwell and go into the menu that lets you monitor hood switch state in realtime
- Pull the hood release inside the car, hood pops open, hood switch state should be open
- Fully open the hood, take a screwdriver or other tool and press it down into the passenger side hood latch mechanism to close it
- Hood switch state should now show closed even though hood is open
- Make sure you pop the hood release to re-open the latch when you're done, you may need the screwdriver again to get it to open since you won't have the spring on the hood to pull it open
I believe the right part number is 65601-1MA0A. There's some confusing part pictures and data online that make it look like that part number is for an entire set, but IPD confirmed in the comments on this page that it's the passenger side latch only:
https://www.infinitipartsdeal.com/parts ... 1ma0a.html
There's plenty available on eBay as well for a bit cheaper.
Good luck, sounds like you're probably on the right path...
