got_chub wrote:not entirely true. i just switched from 205/40/17 all around to 225/40/17 & 235/40/17 and my car is now about 1" higher. i hope you know that the series is the percentage of the width.
The aspect ratio is the height of the sidewall based upon that percentage number of the tread width. Meaning, a 40 series tire has a side wall that is as high/tall as 40% of the width of the tread. So, a 205/40 tire has a sidewall that is 82mm high/tall (205 x 40% = 82), while a 225/40 tire has a sidewall that is 90mm high/tall (225 x40% = 90), and a 235/40 sidewall is 94mm. This is a 12mm difference in back, 8 mm up front. You then have to double this difference to get your change in overall diameter bc it is a change in sidewall height, not the the OD. Use this link to get a better understanding of this
http://www.1010tires.com/TireS...ubmit.It takes 2.54 centimeters to = 1 inch, so this results in a change of 16mm up front and 24mm out back, or ~5/8" (f) and ~15/16" (b) in overall diameter increases based upon your tire/wheel combos. Next time, measure the gap between your tires and fenderwell, and the the gap between your framerail and the ground before you switch tire/wheel sizes so you can get an accurate measurement of the changes. Also, keeping the same OD keeps your odometer/speedometer correct. A Google search will bring up many sites that let you plug in stock tire/wheel sizes and the sizes you want to change to and let you know how the OD compare so you can keep the same OD with larger wheels/shorter sidewall tires. Keeping the same OD will maintain the same ride height/fender gap even with larger wheels. You have to use lowering springs/coilovers or the wrong OD wheel/tire combo to change the gap. Using the wrong OD wheel/tire combo will mess up your speedo/odo, make your final drive ratio shorter/taller (shorter if OD is less, taller if OD is more than stock). Shorter final drive results in increased tire wear, bc the tire makes more revolutions to travel the same distance, easier to spin out if you've got the power, higher RPM's at any speed in any gear than before. Taller final drive will hurt acceleration in a stock KA or stock SR or any motor that doesn't really make a lot of low-end torque. Also, Nismofly and Adrian do know what they are talking about. Take their advice and remember that not everything translates well over typed words on the interweb.
Modified by homeslicej2 at 9:15 AM 2/15/2008
