getting sr to run
justinNISMO
Car: 90 180sx with sr20det
i just got my sr in it starts but there are some bugs and i don't know how to correct them idle is irregular up and down , sounds like it it missing may be a timing issue? i know it can be timed but i dont know b/c of the coil packs and last but not leased it will occaionally just die if any one can help please. Thanks JustinNISMO
180fan
Car: 89 fastback
oscillating idle, check the MAFS, IACV, and vacuum first.
With the MAFS, make sure it's clean, and the contacts are good, the wiring is good, ie check the voltages through the wires.
IACV, make sure it works and the valve is working and clean.
Vac - make sure you've got vac with a gauge. If you see the vac drop or is too low, use carb cleaner to see where your leak is.
If the idle isn't oscillating, then you might want to wait till it's warm, with the TPS plug pulled and the base idle set to ~700-800 rpm and then check the timing eh?
report back with whatcha get.
justinNISMO
HOW DO I CHECK THE TIMING I AM UNSURE
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
plug a timeing light into cylinder # 1 and shine it at the crank pulley, there are marks on it, I believe the timeing should be 20 degrees off TDC
Neil
Car: shooting laser guns
Can you plug the sensor onto the wires going to the coilpack and have it work properly? i wondered that today after looking at my motor on the engine stand.
IanS
what I did was stick an old spark plug wire on the end of my coil pack, and timed it that way
