You might try and find out what comes with it (from whomever is selling it to you). The software costs extra if you dont already have it. Also find out what harnesses and sensors come with it (from the seller), you will need those also (which can be purchased separately elsewhere).page02wrx wrote:I'm not exactly sure how this works
I can get a killer deal on one.... but I don't understand it...
Is it universal? Or what.... or do I need some type of software?
Is E-manage compatible with the CA?
I'd like to know cause I'm swapping mine into a new shell and if its possible for me to wire in management NOW, it will really help me in the future I think.
Ok I'll find out more information, but can you tell me if buying it, even say without software/harness I would be able to make it compatible with my ecu?mbmbmb23 wrote:
-m
I have a friend really good at doing the whole wiring ecu thing helping me to install it...johngriff wrote:I use the greddy emanage ultimate.
The install is a PITA, i would recomend prof installation.
W/ Emanage Blue, you get a "base software" and then can but the "full software" for another $100..
Emanage ultimate, is all inclusive, get that.
Does is work with ca? Yes
Get the AF/R harness when you order it so you can import your wideband and use O2 Feedback.
i love youfloat_6969 wrote:There is a link to the FSM in the stickies. Every bit of info you would need to wire in the emange is in there. IIRC there is also a write up for installing the emange as well.
I only have access to the greddy emanagejohngriff wrote:well.
Dont get the blue. You might as well just use an safc.
Get the ultimate, it is teh sex.
And get the af/r harness. I am not lying to you.
Offhand, I know the ultimate does have the install instructions in the supplied booklet. But there is nothing wrong with having the FSM handy.
Freaking 9 hour install..... but I am persnickity not to on my track car.
How do you compare the blue version to an safc.. an safc only does Air.. blue can do air, fuel, sub injectors, data logging, vtech control and heap of other functions if you buy the correct harnesses and set the unit up right.johngriff wrote:well.
My friend says you can wire in a harness to actually scale the injectors, and not manipulate the AFM. Edit: But i cant seem to find the harness so perhaps it does just manipulate the MAF volts.johngriff wrote:EHh maybe you dont understand, I HATE the Safc.
The blue is based around AFM manipulation
The ultimate works off of I/O on Spark and Ign, plus tons of other features, not mention greddy is has put a fork in the blue.
Get the AF/R harness, because jay will be your friend forever because he can datalog the wideband against the ins/outs in the emanage, instead of feedback only.
You're telling me hybrid dynamics isn't going to be able to safely tune my greddy emanage?johngriff wrote:its going to be a constant battle between afm and timing.
It sucks.
Just do the Ultimate.
Well I plan on, as of right now, simply running the gt2871r with 660's or perhaps bigger injectors.dash wrote:several ca18s on sxoc have sucessfully run emanage blue.Last one I recall was over 300hp.First was a couple years back and allowed that ca18 to run a T3 @20+psi for 2 straight years. Did have some misfire issues when trying to 'advance' ignition timing, but eventually figured out a 'work-around'. Results? nuff said.Nothing wrong with the blue IF you undrstand what you're doing.
Any running examples of a ca18 with the ultimate ?
Sorry I do not follow this forum. You delete my post then say I am entitled to my opinion? Talk about counter active.float_6969 wrote:Good Morning, ease up man. You've made it PAINFULLY clear that you don't think highly of the eManage blue. That's fine, you're entitled to your opinion. But your constant, repetitive, input isn't helping anyone.
He's not getting the Ultimate. If you can't accept that then quit posting in this thread.
Either way the point is I'm not getting ultimate. Clearly the first post states I'm getting a good deal on emanage.... so unless you find me ultimate for $100 I'm not getting it.good morning wrote:
I have years of high end tuning experience. I do it for a living. I think it is funny johngriff giving great advise and it is throw away.
Oh well.
IDK FTW you're talking about. I didn't delete any posts...good morning wrote:
Oh well.
Like I said, I do not follow this forum. I remember a e-manage thread with the same posters.good morning wrote:
I do not see why it is so hard to understand that people are trying to help with info and are brused off because it is "cheaper and easier" to do it one way. You will have problems, it is that simple.page02wrx wrote:
I'm not asking about ultimate either. So after its mentioned once, and shut down, it should not be mentioned again. It's like some one else coming in here telling me to get the AEM stand alone... The topic is not about the AEM stand alone.
Either way, as long as hybrid can knock out my closed loop and long term fuel trims, along with my timing map, I HIGHLY doubt I'm going to have any problems with the base emanage.
Ultimate seems easier to tune with, especially for a novice. But I'm NOT self-tuning the car.
Right, because a certified tuner isn't going to be able to scale my timing table to pull time according to my MAFV manipulation. The main concern with lying to the computer is figuring out the side effects of what happens. If it manipulates the MAFV, then its directly effecting load vs rpm and when timing is pulled, which SIMPLY MEANS timing has to be pulled earlier in the timing table, along with fuel.good morning wrote:
I hope the best, good luck.
Float I cant seem to find the actual e-manage FSM in the stickies, maybe I"m just overlooking it but could you link it to me?float_6969 wrote:There is a link to the FSM in the stickies. Every bit of info you would need to wire in the emange is in there. IIRC there is also a write up for installing the emange as well.
