 Write up on installing Emanage into CA18 S13 240sx/Silvia/180sx.
rexhunta
Sniffing Laundry Powder
Nissan S13 Silvia, CA18DET
Bunbury, Western Australia
2-2-2005
GREDDY EMANAGE INSTALL INTO CA18DET S13.
Items used :
Philips Screwdriver
Soldering iron
Heatshrink
Solder
Cutters
Electrical tape.
Easy forward install, most are just tap ins, apart from these wires. Follow closely, otherwise the car will not start. Please Make sure you disconnect the battery, and while disconnected push the brake pedal a few times to clear ECU. Please only install if you are an auto sparky, or very very confident with wiring. Otherwise theres many problems you can come across, and you’ll either break your ECU, your emanage, both or a lot of other stuff… so a very big WARNING.
Also, when viewing plugs, view as wires go into them. Otherwise it will be back to front.
AIRFLOW METER INPUT.
Cut the Air Flow Meter wire to intercept, WHITE goes to AIRFLOW METER, GREEN wire goes to ECU.
IGNTION TIMING
The Ignition timing harness is a little more fiddly, it requires cutting of every wire, and then resoldering on, so be very careful with this one, as if you go backwards, you will not be able to start your car.
Same principle on all wires, WHITE is the input from the ECU, BLACK is the output to the COILPACKS
these are the pinouts of the harnesses on the emanage, just as you would view them if they were plugged in
Pinouts on ECU As you see them when you take out off the cover. Note, where theres the orange writing, thats where the coloured wires on the back of the emanage has to go.
Any help, i am easy to get hold of. Right click photos and save as for clear copies.
Pete
Modified by rexhunta at 6:40 PM 9/26/2006
dash
s13 ca18
dirty south
5-5-2006
 « Re: Write up on installing Emanage into CA18 S13 240sx/Silvia/180sx. (rexhunta)
Are you using a bone stock ecu ??
Thanks for the writeup!
Over here we're lacking in the tuning department for those who want to retain nissan electronics.
Until that 'Nico' ecu programmer comes along with a good mafs/injector tune, we'll have to play with piggybacks.
Miata guys are doing well with their Emanage blue. Those that have tried it, swear by the Ultimate which they say is substantially better.
I spoke to one tuner who ran the EMU on his street mitsubishi and it did indeed allow him to get rid of his AFM as advertised. He said it drove/tuned considerably better and made solid power at 28psi.
Would be interesting on a ca18det.
dat_twinkie
1992 240sx coupe, RHD conversion, CA18DET power
Biloxi MS
8-11-2006
 « Re: Write up on installing Emanage into CA18 S13 240sx/Silvia/180sx. (dash)
i wonder if the emanage ultimate is that great, since it's still consider as a piggyback unit right?
i was looking into it when it first came out for my ae86 but nobody had it yet... i wanted to put it into my ae86 so i could run individual throttle bodies on it.. and when and if you take out the afm to run a map setup do you have to get a vacuum or map sensor?
boost_boy
1990 sentra w/ CA18DET
Miami Fl
11-14-2002
Hey Pete,
I'm going to sticky this because you did an outstanding job and this information will prove to be useful to some of the guys/girls who want to take the e-manage path. Again, outstanding job!
Dee
Who's selling their CA18 next ?
Forged pistons are no insurance for ignorance .
Spending money foolishly doesn't equate to a high hp car .
Being cheap all the time equates to a waste of time
And lastly, I'm not done; for I've only just begun, so stay tuned
Dee
rexhunta
2-2-2005
Quote, originally posted by dash »
Yes i'm using the bone stock ecu, as the emanage is a piggyback, all it does it takes or gives points. So easy to use.
I'm using mine to control my RB20 AFM ( just a drop menu away in the software, that simple), my injectors, and the timing. Cold starts you don't have to program, as it uses the factory cold start programmed in the ecu.
I haven't used it as a mafless setup, but a close friend of mine is thinking of doing it in his 4 door 34 drift car, so we'll see how he goes, but that will be running an SR, but it'll be same setup.
I'm using emanage in my car ( ks13 silvia, ca18det) and its a blast. every now and then i get a little error of incorrect timing order, but that's prolly cause my coilpacks are ****ting itself or somethign stupid, but i only gewt that not even once a month now. It's such a good basic ecu. I have many guys over here who are going to start using it after seeing how easy it was in my car.
Quote, originally posted by boost_boy »
Hey Pete,
Dee
Thanks alot man, i have also posted this info over at http://www.nissansilvia.com which is a Australian based S1x site ( absolutely massive for info as well as this site), so it's awaiting to be approved into this tech info section too, as i get at least 3 pms every 4 days about it..
Pete
CaEric
91 KA-T PWERED COUPE
Poughkeepsie
1-4-2006
So the emanager is unervrersal like a safc ? basicaly any one will work ?
ka-t >Ca > Sr
Ohh baby can u feel the TQ?
Having no pop up lights on an S13 is like being white with chinky eyes. It's kind of f*cked up.
rexhunta
2-2-2005
 « Re: Write up on installing Emanage into CA18 S13 240sx/Silvia/180sx. (CaEric)
Quote, originally posted by CaEric »
Correct. It is universal, as the emanage has no settings in it all from factory.. it's just a plus/minus points thing.
Pete
dash
s13 ca18
dirty south
5-5-2006
Rex,
Have you verified the Emanage ability to advance AND retard timing ?
I know they used to have mis-fire issues on the ca18.... I'm wondering if your 'ignition error' could be related.
Yeah, lots of folks get satisfying results using Emanage.
Check out this nice 300hp ca18 tuned via Emanage blue
http://www.sxoc.com/vbb/showthread.php?t=246845
rexhunta
2-2-2005
Rex,
Yeah, every now and then i get mis-fires, i just thought it was cause of bigger injectors/AFM was too much for cruising speed.
I can stop the ignition error now, but just keeping it above 1000rpm, so i might change my idle up, i can do that via the emanage as well.
I've just picked up parts of an E-01, but need a few more parts, so when thats complete, i'll write up how to whack that in, and how to tune the emanage via the e-01 controller ala power fc and hand controller.. except this is with a top of the line boost controller.
Peteq
rexhunta
2-2-2005
OKay, was out in the car taking some fuel out and turning my boost down so save some fuel, and thought i'd get you some screenshots of the Support Tool.
This is on my laptop, it runs win98 se.. pentium 200 with 160meg of ram.. not the greatest, but she works fine..
This is the data logging screen, was getting some data from letting it idle, so see if i can fix my dropout problem..
Okay, the next few are from my desktop pc, as the maps and logging i save on the laptop, i put on the desktop to check out and see whats happening.. i try to datalog every 2-3 weeks, just the trip to work and back, to see if everything still the same... yes i'm a bit anal on it..
This is the main config screen... where you can change your injector size, and change the AFMs, and which maps you use.
And finally, this is the main maps page.. these are my fuel and timing maps.. exactly like an SAFC, you give or take timing/fuel using this.
Pete
Chris859
'89 240sx w/ca18det
Pinetop Az
8-8-2006
Sweet info, I was thinking of using an safc2 to tune for larger injectors/maf. But I think i'm sold on trying out an emanage now! Nice write-up, simple and to the point!
'93 Cougar, Built 5.0, 5spd swap, upgraded suspension - Daily driver
'95 Eclipse rs, other daily driver
'89 240sx coupe, ca18det, silvia front end - Project/fun car
'89 R32 skyline, being torn down for inspection and rebuild.
'71 Subaru Star, EJ20tt swap, awd conversion - in progress
Thepest
s13 coupe
Las Vegas nv
11-23-2006
That was a big help!
page02wrx
2004 350z
Worthington PA
4-4-2007
 « Re: (Thepest)
Hm... I need to figure out what I'm looking at in those pics.....
Perhaps I"ll understand it more when I see the emanage and ECU, I've never seen the ECU on my CA18 Yet
2004 350z. True dual catback
Bizzle
RS13
Ashford kent
6-3-2007
So do you wire in the coil pack wires in together??
I.E Yellow White + Yellow Black, Together into 11?
rexhunta
2-2-2005
coilpacks should be done individually mate.
e.g 1 2 3 4 to 1 2 3 4
not 1 2 1 34 2
driftin8ez
Jersey's Finest
92 Coupe, Turbo Miata
central nj
3-18-2004
which emanage did you use? The ultimate or just the regular one that goes for like $250?
Mesh Crew Fuel Pump Cut-off Tech Article RB20/25 N60/N62 MAFS Wiring CA18DET
_______________________Because If She's Not Topless You're Not Having Fun____________________
» Return to CA18DE / CA18DET Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
