IanS »
https://forums.nicoclub.com/ians-u23642.html
Sun Jul 07, 2013 10:44 pm
Hmmm
Define seizing. Does it not spin up when the clutch engages, causing the belt to squeal, or is it stopping durring normal operation, and causing the belt to squeal.
Have you checked the belt tension? Older systems tend to be picky about belt tension, they want a very tight belt.
Excess refrigerant can cause lock up due to liquid entering the low side port, though it takes a pretty heavy overcharge to cause this.
It could be that the compressor is oil slugging. The new compressor was likely filled with oil when it was installed, and if the system had been charged a few times prior, each time with oil being added, you could have an excess amount of oil in the system. The easiest way to fix this, is to replace the receiver/dryer, and fully evacuate the system. This should clear excess moisture and oil from the system.
The other issue, may have been contamination in the system. When the prior compressor failed, its possible that it dumped shavings into the systems, which then killed the new compressor.
