motoguy128 wrote:I guess my problem is that the only adjantage a better ground will have is reducing resistance in the circut that is being grounded....since copper has less resistance than steel. I don't see how it affects voltage variations which are a result of sudden changes in load on the electrical system. We're only talking about small improvementis in effeciency.
As for the ignition system. Small changes in battery voltage will not have a significant effect on the strength of the spark.
As usual, if adding some extra wires could gain 2 or 3 HP, manufactures would be doing it.
Take a look at my other threads regarding grounding kits if you want a detailed reason why manufacturers aren't doing this.
As for the gains. I have too many people with positive results for your disbelief to be warranted.
Ever heard the phrase "Garbage in garbage out"?. That's somewhat applicable here. If there is noise and variety in the input voltage, then the sensor output is going to be off as well.
The G35s see better throttle response because both the TPS and Drive by wire systems can get good signals to the ECU.
Transmission shifting is improved because the TCM is grounded and doesn't have to transmit electricity through the bellhousing, to the block, through the small factory ground, through the chassis to the battery.
Sorry if this is coming across as argumentative. It's not meant to be.
