To: 2007+ Altima 3.5SE owners only who are interested in aftermarket downpipe.
This thread is meant for serious buyers and to get this into production! Please read EVERYTHING in this post.
This exhaust component will replace your pre-cats on each side. It is right after the headers and before the y-pipe. It is a direct bolt-on and will work with your stock or aftermarket exhaust. Installation can be a DIY if you have experience and tools.
Fast Intentions HFC, TP, or Resonated-TP will all be less restrictive than the OEM pre-cats. Thus freeing up your exhaust and increasing power.
More information can be found here:
http://fastintentions.com/exha...t.htm
Hi-Flow Cats: Improved with aftermarket cat. Much superior than OEM cats. Improve sound. Picture Example:
Test Pipes: This will eliminate all cats. It will make your exhaust louder and may cause raspiness.
Picture Example:
Resonated Test Pipes: Just like test pipes, but with the added resonator(muffler). It will help reduce noise level and raspiness compared to test pipes.
Picture Example:
Test pipes tend to give the most power, but all will be similar in terms of gains. It is up to buyers preference in what they are looking for. California people would probably consider HFC more because of strict emission laws.
Expected gains: 7-12 WHP/TQ
Price can vary depending which one you will want. HFC being the most because of the cats being costly. Resonated test pipes being in the middle. Test pipes being the cheapest.
BEFORE GOING ON. You will need to ACCEPT that you are willing to pay for one of the following: $250 if you want TEST PIPES, $350 if you want RESONATED TEST PIPES, or $500 if you want HI-FLOW CATS. If you accepted one of those, please continue. If not, please don't continue.
Note: These pricing are just estimates and should be very close in what you would be paying.
Here is what you will need to post. You must respond to all 4 questions or your post will be ignored.1. What is your name or forum name?2. What vehicle do you drive? You must include year and model. Transmision is a plus.3. Which downpipe are you interested in? Hi-Flow Cats, Test Pipes, or Resonated Test Pipes.4. When will you be able to pay? Right now, in 1 month, in 3 months, or in 6 months.
Example:1. Mr. Jones2. 2008 Altima Coupe 3.5SE CVT3. Hi-Flow Cats4. 1 month
Thank you all.
