Postby
IanS »
https://forums.nicoclub.com/ians-u23642.htmlTue Jun 17, 2008 5:51 pm
It should come with one.
If not you have two options, if there is a groove in the adapter for a gasket to sit, then just grab a gasket off one of your oil filters and use that, if its all flat, I would think RTV would be the only way to go.
Post pictures of what you have, we can give better advice that way.
Postby
spider_slayer »
https://forums.nicoclub.com/spider-slayer-u20388.htmlMon Jun 23, 2008 10:11 pm
i'll work on pictures later in the week. but its all flat. its jsut the adapter plate that the oil filter screws onto and block. i through rtv would work but i wanted to make sure there wasn't a gasket i needed.
Postby
PhopsonNY »
https://forums.nicoclub.com/phopsonny-u10816.htmlMon May 31, 2010 6:01 am
I know this is old, but I like closure and it would help someone else
I had to use RTV because it was an emergency fix before a track day.
So far so good
The part you are looking for is Nissan # 15066-5E510
You will need two of them.
