SideWays=smiles wrote:the walbro should not effect the float thing, it may be the electical connections.
That is what I believe as well. I have also installed the fuel pump in question and I recently made it to a gas station where my wallet was able to feel the pain of my very first fill up. The Fuel gauge worked flawlessly after 2+ years of having the gas tank removed, and left upside down in the trunk of the car. You have to make sure you didn't bend the metal the float is on when removing/installing the pump. From what I saw, there is not much space between it and that plastic channel thing for the gas. It might be rubbing or stuck against it.
