i did pretty much everything...schanne wrote:What did u do?
Conquerer wrote:Was anyone else tempted to say "that's what she said" at the topic title?
you mean THREADJACK. lol. To OP or you, I am assuming there is definetly something wrong with your timing. OP had cams installed so thats an important factor to look at.Xj220gt wrote:I dont mean to thread steal but, im still having the same problem
I took out the spark plugs over night and waited for the gas inside the engine to evaporate, then I switched the rotor inside the distributor cap around to the oposite side as to switch which stroke it was on. Still nothing and it actually sounded weaker than before. I switched it back and made sure all my plugs were inserted and called it a night.
How did you go about checking your starter?
I just got the starter today.. and i don't have a garage so i have to wait for the weather to cooperate.. it just snowed yesterday. I'll let you know if the starter does the trick though.tEknoS13 wrote:
BTW: DubsSuck, did you get your car to start after finding your starter was dead?
ok if you put your engine at DTC of the compression stroke, your distributer at #1 and have your cams in this possition:it won't matter where the chain marks are. that should fix your timming issueXj220gt wrote:I have tried the screw driver in the cylinder and rotating the distributor rotor as to set it onto the second compression stroke. Either way, my car didnt start. Im thinking it might be because I probably flooded it. Im going to try it once with each stroke today and see what happens. and no, I only changed my timing chain, so I too am almost positive its my timing.
Thanks for the info guys. Really appreciated.
the fule pump primes the line for 5seconds when you are trying to start the car and if i doesn't start because of incorrect cam timing it is possible to flood a fuel injected engine.. im gonna tell you straight up, i've never went to school for this stuff everything i know is from experience. so if i'm wrong please correct me, but i'm telling you now i've flooded my engine.DubsSuck wrote:i know im getting fule and i know im getting spark and there isn't any reason why it shouldn't be getting air... i already flooded the engine.we're thinkin starter
hehehe you've never driven a rotary.jeff420 wrote:whats all this talk of flooding the engine? i thought you couldnt flood a fuel injected engine. the injectors just spray a little bit when you turn the key. correct me if im wrong but ive neeeeever flooded a fuel injected car. carb'd yes but not fuel injected
and when you try to start your car the starter is turning over isnt it? i dont see how a bad starter could keep you from starting the car unless it just plain doesnt work. have you performed a compression test? that would been the next thing i did after checking for fuel and spark
well its kinda hard to get your car to start if its flooded.. and to answer your question yes i did check my compression and it was a good 60 ps wayy tooo low. thats when i found out that my cams were in the wrong possition. After i timed and repossition them i took the vid and guess what there was enough compression for combustion!!hopefuly the starter will do the trick.. which btw triped the breaker at advanced during the bench test cause we were putting so much amprage through it. so yea its dead.jeff420 wrote:have you checked your compression? how can you know its flooding if you cant get it to start at all? it could just have no compression. im willing to bet its not flooding but thats just my .02
rotarys flood really easly, i stalled my friends rx7 once and it flooded.jeff420 wrote:nope. whats that supposed to mean btw? im a little slow at times, lol.
