G50 tension rod bushings.
dnudelman
Car: SOLD 1994 Q45 Silver/Grey
I've ordered the ES 7-7105 as described in this thread:
g50-tension-rod-bushing-recommendations-t568810.html
The OEM bushings look like they have an OD of 69mm. The ES7-7105 for Z32 measure 61MM od.
Do I have the wrong part or is the 94 q45 Base different? Thanks
Looks like same part number for strut rod series 1 and 2 5446860U00
dnudelman
this is what is on the energy suspension web site for Q45. Doesn't look like what I got in the 7-7105 package
http://www.energysuspensionparts.com/spf1202ak
this looks like the oem
http://www.energysuspensionparts.com/w81707a
OwnerCS
I posted this info in another thread a few years ago. These are working just fine. My 91 model G50 uses Z32 in the front.
http://www.energysuspensionparts.com/7.7105
OwnerCS wrote:
Sun Mar 15, 2015 11:04 am
dnudelman
Yes, I am baffled. Did you burn out the rubber bushing or press out steel shell? Is the OEM G50 bushing from 91 smaller than the 94?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I believe 90-96 except active have the same bushings. Everything I've seen is Z32 uses the same bushings in the front as the Z32.
I would not burn them out, the shell on those bushings is really thick, they press out very easily.
