Does anyone have a poly tension rod bushing recommendation for the G50?
I started experiencing a creak on the front passenger side.
The struts, strut tower bearings, sway bar end links, sway bar bushings, and related bushings are all new. My Infiniti tech buddy said I needed new tension rod bushings as the original silicon filled equipment has leaked out the silicon.
There seem to be a lot of choices for link bushings.
Any recommendations?
I did find the following.
http://www.partsgeek.com/gbproducts/WC/ ... PAodKQQA3Q
Craig
